Ford OEM Factory Alarm with Remote Start Gold System... - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-27-2006, 11:30 AM
stebab's Avatar
stebab stebab is offline
stebab is starting off with a positive reputation.
Does this item have the diesel delay starting?
Kit Includes:
  • <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">2 Remotes <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">Alarm w/shock sensor <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">Remote start w/pats <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">Starter kill <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">Flashing lights <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">LED <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">Full installation manual for your vehicle
  • Hood bypass
Kit numbers are:
  • <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l1 level1 lfo2; tab-stops: list .5in">2W7Z-19G364-DA - REM START / DELUXE
  • 2W7Z-19G364-HA MODULE
Then it says for the remote start I will need one of the following pats bypass.
(1 pats module included)
  • <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l1 level2 lfo2; tab-stops: list 1.0in">1L3Z-19G365-AB PATS MODULE <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; mso-list: l1 level2 lfo2; tab-stops: list 1.0in">1L2Z-19G365-AB PATS MODULE
  • 1S4Z-19G365-AB PATS MODULE
Which one of those do i need and what is a PATS bypass?
What is the retail on this?
I have the 2006 250 diesel.
Old 01-27-2006, 11:43 AM
EnviroCon EnviroCon is offline
EnviroCon has a good reputation on FTE.EnviroCon has a good reputation on FTE.EnviroCon has a good reputation on FTE.
Quote:
Yes. It has a built in diesel timer that can be turned on, that will delay the start function for 30 seconds after the system turns the ignition on.
You don't need a PATS(Passive Anti-Theft System) bypass. SD's don't come with PATS. PATS uses the "chipped" keys. Which of course we don't have.
I have no idea what retail is on one of these systems.
Old 01-27-2006, 04:08 PM
OverHeight OverHeight is offline
OverHeight is starting off with a positive reputation.
I have it and works great!
Paid $575 cdn installed at the dealer.
Old 01-28-2006, 08:02 PM
stebab's Avatar
I actually just found this link... this is very cool
http://www.gemsen.com/ford/Pdf/101825_8_Gold_Owners.pdf
Then if you truncate that link, you get this one...
Which may be even cooler.
Old 01-28-2006, 08:30 PM
stebab's Avatar
Also a good link on the different models available.
http://www.p71interceptor.com/remote...lverbronze.pdf
Transmission worries! pjcat Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 10-03-2015 01:48 PM
Changing the upper (secondary) fuel filter in a 6.0L bismic 6.0L Power Stroke Diesel 56 08-10-2015 11:35 AM
Dual Battery Disconnect bismic 6.0L Power Stroke Diesel 8 04-09-2015 01:47 AM
NE Georgia Swap Meet, Aug 4 Brad54 Events & Happenings 0 08-01-2012 01:58 AM
NE Georgia Swap Meet, July 7 Brad54 Events & Happenings 0 07-05-2012 10:43 PM
Tags
2002, alarm, anti, bypassing, f150, f250, factory, ford, oem, passive, prooe4bs, remote, start, system, systems, theft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
