302 spark plug #? Autolite 45? 46? higher? What do you run? - Ford Truck Enthusiasts Forums
Old 01-26-2006, 11:17 PM
packrat56's Avatar
packrat56 packrat56 is offline
packrat56 is starting off with a positive reputation.
I have a 302 from 73' 2bbl Holley, the PO said it has a "mild" cam. It has never idled right and I'm playing with plug heat ranges now, seems like it loads up at an idle, but wont idle when lean either. I have been over all the "normal" stuff, cant figure it out...
What # plugs are you running in your 302? How hot can I go?
Old 07-19-2012, 12:24 PM
miketaheny miketaheny is offline
miketaheny is starting off with a positive reputation.
A very good question.
Old 07-19-2012, 02:23 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Sounds like it might be carbon build-up, runing the engine at a fast idle, you can trickle (very, small) water or ATF fluid down the carb to dissolve/break it up. In regards to plugs, you can go up or down 1 step but timing & fuel mix will need to be adjusted. I'm betting it is either carbon or an electrical based issue though.
Old 07-19-2012, 08:56 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
What are you setting the initial timing at ? And what ignition system are you running ? If you're running points ignition and/or are using the factory timing of 6*BTC, that's more likely your problem.
Old 07-20-2012, 02:15 AM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
Autolite 45 is stock plug for that engine.
Old 07-20-2012, 10:59 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
All good advise. Bought a vehicle about a year ago with same issues and black plugs. I did go up one heat range, but have slowly cleaned engine and carbon deposits running Seafoam and a little Marvel Mystery in the oil. Keeping a close watch on condition of the plugs, have had to go back to the colder plug and back off timing a couple degrees.
Carb wont idle Harley Hill 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-23-2016 07:53 PM
302 to 351 1996 f150 dozernsasha Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 19 02-12-2016 11:36 PM
Distributor question for 400 ltlvt 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 3 06-09-2009 02:57 PM
New 302 running rough.... ssanto Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 08-03-2006 07:51 PM
302 Preventative Maintenance Big Red 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 11-24-2003 09:35 PM
Tags
302, 302x, 45, autolite, engine, fit, ford, motor, plug, plugs, run, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
