codes and questions, scanned my truck :S
My scanner finally came in today. I had it scanned about a month ago and I had P0133 and P0153. Today when I scanned it, only P0133 was in the computer. I ran some tests and bank 1 sensor 1 o2 sensor came up with .460 volts. So is my o2 sensor in dire need to be replaced or do I have to start looking at other things?
Also Catalyst Rear to Front Switch Ratio Bank 2 (CATRAT2) is 1023.98 meanwhile CATRAT1 is .8 is this very bad? What does it even mean???
Evaporative Maximum Vapor Generation Rise Limit Phase 4 (EVAPRISEL4) is -64.00 inches of water with minimum of 2"
There is misfire on cylinders 7 and 8 which is ok since it's a V6 but, for cylinders 9 and 10 it says pass, whats with that?
codes for missing cylinders says you coded the wrong engine into the unit or the unit is bad.
What do you mean you ran tests and got .46 V on O2? You should be running dynamic, real time test and watch th eO2's switch above and below .45 V. If you got a steady.46 V, I would suspect a bad sensor 1st.
I don't understand a switch ratio number. Sorry, I'm sure it means something but my OBD-I doesn't use that terminology.
I got mine from www.OBD-2.com With my setup Jharger, I just plug it in, go online and it does everything itself. Maybe I'll have to shoot an email over to the guy I got it from.
So what's that, about 144K miles? When O2's first came on the seen in the mid 80's, manufacturers put a timer on th car, some very simple with a light on the dash, that would go off at 80,000 miles. This was to remind people to replace the O2's.
I think a paranoid mechanic would replace them at 30K miles, proactive 40K, conscious one at 80K and everyone else when the run into problems.
I think that for such a critical EFI control sensor, why not make sure it's always in top condition?
Originally Posted by NON
Speaking of Scanners/Code Readers....
Where can I read more about them and obtain one along with and additional material I might need.?.
Do we really need to graph O2 output? Maybe R & D activities at an engine building plant. Technology is great, don't get me wrong. But proper application. So far, mechanics have been OK with just being able to tell yes or no that an O2 is switching. If no, fix the lean or rich condition or replace sensor if all else fails.
Kind of like the $1000 cam corder I bought. I've used only about 1/10th the features it has.
rogerranger2122
1983 - 2012 Ranger & B-Series
23
08-08-2016 06:24 PM
tbush08204
01-20-2016 07:29 AM
gaviotas
02-04-2004 09:44 AM
