Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Oklahoma Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
  #1 (permalink)
Old 01-24-2006, 04:28 PM
cigarxtc's Avatar
cigarxtc cigarxtc is offline
Garage is empty, add now
cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.
Local Audio Expert Help Needed......
....Okay...I give up....I throw in the towel....I'm beat and can't figure out how to kill the alternator whine noise in my stereo system in my '78 F150. It wasn't there with my previous cheapy Jensen cassette stereo. I have already exhausted every avenue via the FTE Audio Forum, except changing the RCA cables to another brand or changing my custom Taylor 9mm plug wires back to stock. So now, I'm asking for any help from you local audio experts. Would anybody be interested in coming over to help me troubleshoot this to figure out what I need to change/correct? I'm up in Owasso. I know we're not supposed to do any tech talk here, so I'm using this opportunity to ask for some local members to come over to help me figure this out. I can offer lunch and a cold drink if that would make it worth your while?.
__________________
-Ron
Daily Driver 1978 F150
  #2 (permalink)
Old 01-24-2006, 05:50 PM
Traxxis's Avatar
Traxxis Traxxis is offline
1994 Ford Ranger
My Garage
Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.
Hmmm.... you should have said something about it the other night----we coulda taken a look (not that there is anything I can do----but it never hurts to have a fresh set of eyes take a look).
I'd be glad to come sometime, though I am unsure of when I would be able to make it.
STan
  #3 (permalink)
Old 01-24-2006, 05:51 PM
1975Ford's Avatar
1975Ford 1975Ford is offline
1975Ford is gaining momentum as a positive member of FTE.1975Ford is gaining momentum as a positive member of FTE.
I think the part you are looking for is the capacitor or a noise suppressor (it is round, about 3/4 inch in diameter, and one wire attaching to it in the center), one is mounted by the coil and hooked up to the wire coming out of the coil, the other is mounted next to the voltage regulator. Take a look and see if your truck has either.
__________________
Word of advice "Take your time, clean and prep part, and don't cut corners"
  #4 (permalink)
Old 01-24-2006, 06:01 PM
diamanti1 diamanti1 is offline
diamanti1 is starting off with a positive reputation.
Try going directly to ground....or running your ground directly to the battery...that is the primary cause of motor noise.
  #5 (permalink)
Old 01-24-2006, 10:24 PM
cigarxtc's Avatar
Thanks, Stan. I figured it was too cold and dark to work on it at the meet.
1975Ford, yep, both caps are there; one on the coil, one on the volt regulator. I'll take them apart and clean the connections this weekend to see if that makes a difference.
diamanti1, yep, did all that as per very lengthy discussions in the FTE Audio Forum. It didn't help.
__________________
-Ron
  #6 (permalink)
Old 01-25-2006, 08:43 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader SwOkcOffRoader is offline
1952 Ford F-1
My Garage
SwOkcOffRoader is gaining momentum as a positive member of FTE.SwOkcOffRoader is gaining momentum as a positive member of FTE.
do you have a noise filter on the positive wire to the radio??? they are like 15 bucks at walmart...
__________________
Why is there never enough time to do it right the first time, but always enough time to do it again??
....Will work for Rep points....
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
