Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-24-2006, 01:16 PM
parkland's Avatar
parkland parkland is offline
Garage is empty, add now
parkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to behold
WVO - the best idea
diesels only need 2 things to run from WVO
1. WVO has to be kept hot
2. WVO has to be filtered like hell
My 7.3 truck ran off WVO in -30 below winter using tanks and hoses from the dump.
I did make a rat's nest of heating hoses running all over the fuel lines though.
Dont think theres a way to avoid this
I filtered the WVO many times using home-made filters that filtered through newspaper, screen , pantyhose, coffee filters, anything really. Using the newspaper filter last. (i'm not sure exactly what "micron" newspaper filters the oil too, but i just used it, and it seems to work. Takes forever though.
The tank that the oil sits in had a tap on the bottom to let any water out after heating up a little, although never had much in it.
it does not cost thousands of $ to get her going on WVO, and its the best idea cause its free.
  #2 (permalink)
Old 01-24-2006, 07:24 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
Thanks for the info.
I take it your rats nest of hoses are coolant lines from the radiator? How do you address cold starts with this set up? Or are you starting and purging with #2?
Is your 7.3 a PSD or IDI? Any pump or injector issues?
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #3 (permalink)
Old 01-24-2006, 07:32 PM
Fire Rooster's Avatar
Fire Rooster Fire Rooster is offline
Fire Rooster is gaining momentum as a positive member of FTE.
Let us know how things go after 20, 30 ,80 thousand miles
__________________
2012 F150 Screw, 2x4 XLT+, Bad Boy Black[SIGPIC]
2002 F250 CC,SB,4X4,Lariat...SOLD. 2003 X, limited SOLD
  #4 (permalink)
Old 01-25-2006, 11:56 AM
parkland's Avatar
well, unfortunately, i had to park the old 7.3 2 years ago cause the tranny is gone(wont come out of 3rd), and theres just too much rust to justify fixing it anymore.
There is about 20000 KM's on it from WVO though, and this summer, i went and got it running sitting in the field just for the hell of it, after a little "warm up" smoke, she ran fine. (NOt on WVO)
MY uncle gave me a chebby, and now i'm saving for a new PSD.
Cookie:
I had to start on #2 diesel. ITs almost impossible to get heating tubes on the injectors as they go in the block, and if the block is -30, the oil isnt gonna be warm when it gets squirted in there. If you had a helluva block heater, and a heater in the oil tank, and an electric coolant circulator, you could probably start it on WVO, but its easier to just start it on diesel, warm it up, and switch over. In the winter, it takes a long time for the WVO to get hot, especially the tank(mine was 90gal) but even only 1/4 full it still took forever (45 mins) (I always waited for the very bottom to melt, and then drove)
So, to be more practical,instead of letting the truck run forever, get an electric heater for the WVO tank, and plug it into the block heater cord, so when you plug in the block heater, the tank heater comes on. An idea i had, but never did, was to use the exhaust to heat the tank.
That would probably work good, especially when its really cold out. Also, i'm not sure how hot the exhaust would be, but if you could put the WVO fuel line inside the exhaust, that would be even better. I used the coolant idea becuse thats what everyone else on the net does, but mabye the exhaust heat would cause the oil to burn in the line.
Well, my point is that, if you live somewhere cold, Biodiesel is gonna need heating, and if your gonna mess around with heating, you might as well just burn free WVO.
  #5 (permalink)
Old 01-25-2006, 12:17 PM
parkland's Avatar
So, whats anyones thought of putting the WVO lines in the exhaust pipes?
BTW, i'm not an expert mechanic, i have never even torn down a diesel, I just figured that the oil burns when hot, keep oil hot.
Also, keep fuel+heating line wrapped in insulation. I used foam pipe insulation wrapped in electric tape. You could probably use pool noodles wrapped in duct tape.
DO NOT use copper for WVO systems. it reacts. Use steel. I used old steel oil furnace lines.
The coolant line runs through a steel pipe going throught the bottom of the WVO tank.
My WVO tank had a 2" pipe coming out of the bottom, with a ball valve. You'd be surprised how clean you can get WVO with newspaper filters.
My newspaper filter was basically a bucket with the bottom gone, with a layer of chicken wire, screen, then newspaper sheets, and then a piece from another bucket to slide over holding the "filter" on the bottom of the bucket. Before using this filter, i used anyhting i could find to get rid of bigger particles.
  #6 (permalink)
Old 01-25-2006, 09:17 PM
willbd willbd is offline
willbd is starting off with a positive reputation.
I would think the exhaust pipe would be to hot. You might run the risk of melting your fuel lines.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
  #7 (permalink)
Old 01-26-2006, 01:57 PM
parkland's Avatar
use steel fuel lines... ???
  #8 (permalink)
Old 01-26-2006, 09:12 PM
That would be a lot of work. There are a lot of good water heater setups that would be easier to install with out replacing all of the rubber fuel lines with steel.
__________________
Bryan Will
  #9 (permalink)
Old 01-27-2006, 02:27 PM
parkland's Avatar
it only has to be steel on the portion that runs through the exhaust.
Its only an idea, you have to have more money and time than i do to get it "perfect"
  #10 (permalink)
Old 03-17-2006, 01:10 PM
schefner schefner is offline
schefner is starting off with a positive reputation.
Why not coil the steel lines around the exhaust? Like maybe a 1 foot section of the turbo downpipe
__________________
Steve Hefner, Bakersfield CA, 2008 F250SD,5.4.
1997 Explorer EB, 5.0, 2x4, Auto, 153,000 miles.
1989 BII, 4x4, Manual
  #11 (permalink)
Old 03-19-2006, 08:10 AM
Orpackrat Orpackrat is online now
Orpackrat is starting off with a positive reputation.
I have planed of changing to WVO this summer when I can afford it. I hav thought about using the exhaust for heating. I have not thought about wrapping some tubing around the exhaust. Thanks for that post. I have the 1988 F-250 XLT Lariet with the 7.3 nonturbo and I was wondering if anyone knows if I need to upgrade the fuel lines for the heat of the WVO passing through. If you can help, thanks.
__________________
1985 F-350 Crew Cab
V8 6.9 Liter
3-Speed Auto
Manual Glow Plugs
Converting to run WVO, will also convert to custom flatbed with pop-out 5th-Wheel, thinking about making custom popup camper-tent for it as well.
  #12 (permalink)
Old 03-19-2006, 08:32 PM
mobilefleet mobilefleet is offline
mobilefleet is starting off with a positive reputation.
no need for tubes...........I got 3 block heaters on my fuel tank...run them off a 2000 watt inverter so they stay on until I unplug them when parked for awhile....got an air operated oil pump with inline filter......go to local restaurants and pump directly from their vat to my fuel tank, inline filter stops all the crud, block heaters go to 250 degrees max if I need them....don't need to purge diesel because my veggie's always hot enough...don't use veggie on metal fuel tanks though, it will react with the metal and get flakes in the system, use plastic tank
  #13 (permalink)
Old 03-19-2006, 09:14 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1997 Ford F-350
My Garage
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
If you were at all close to the engine, the exhaust pipe would be way to hot.
My downpipe temp goes over 800 degrees when I am pulling a hill with a load.
Comes out exhaust manifold at 1100+ degrees.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #14 (permalink)
Old 03-19-2006, 09:36 PM
Currently and where I will be most of the time when I start WVO I will not have any ac power availible but I plan on having duel alternators and two 850cca batteries mounted in the rear with the second alternator to power them (or however it works out that I install the other alternator and batteries for better performance). How hot is too hot and how cold is too cold for WVO. Thanks for the information on the metal tanks. Will the origanal fuel lines be able to handle the high heat or do they need to be replaced and will heated diesel hurt anything even if it is used for a short time (preheating the WVO and engine for WVO use). Thanks.
__________________
1985 F-350 Crew Cab
V8 6.9 Liter
3-Speed Auto
Manual Glow Plugs
  #15 (permalink)
Old 03-19-2006, 09:48 PM
What if the lines were wrapped around for a short distance about halfway throught the truck for preheating. If it the WVO gets too hot it could have some time to cool before a Vegtherm at the injectors. Could that work? If there is no answer to this question, this summer I might do an experiment with a fuel pump, temp. gauge, and some oil. To me it seems like using exhaust and electric heaters would be easier than coolant. Also another idea, running a pump and alternate WVO lines to circulate the WVO from the tank around the exhaust as a means of preheating the tank. Have a temp gauge in the tank to know when to engage the pump to the exhaust for preheating the tank. Just an idea that came to mind. Thanks.
__________________
1985 F-350 Crew Cab
V8 6.9 Liter
3-Speed Auto
Manual Glow Plugs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
