Turbo downpipe question???
Will a down pipe from a 99 to '01 powerstroke come close to fitting a 97 powerstroke? Is the turbo connection flange the same. What is the stock diameter of a 1999+ turbo downpipe??
I thought I might get one used and modify it to fit as long as the diameter is larger and turbo flange is similar.
Originally Posted by cookie88
Stock 99-03 downpipe it 3", but it has very different bends, and isn't much (if any) better than the stock 94-97 pipe. The outlet flange is the same size.
You would be way better off with a good aftermarket pipe as I doubt the stocker would even be worth your time.
jdeeg4276
09-17-2011 08:33 AM
ghunt
13
11-07-2005 11:22 AM
