Brake problem
Brake problem
I just replaced the front pads on wifes 91 Explorer with rear ABS. When compressing calipers so new pads would fit, I did it slowly, with a large c-clamp. Also adjusted the rear shoes - a bit too much slack. Everything worked fine Saturday and Sunday - took a 300 mile trip - but this morning, she tried to drive it to work, and came back complaining about having to pump the brakes up.
I checked everything out - no leaks, everything tight, fluid full in the master.
Sitting with engine running, first time you hit the brakes, pedal goes WAY down, but can then be pumped up with a couple hits. Same reaction driving it - once pumped up, it stops real well.
Any ideas - gotta get this thing working today!
Thanks!
Rich
Thanks!
Rich
evobuilder
04-22-2012 09:56 PM
