thermostat direction - Ford Truck Enthusiasts Forums
Old 01-23-2006, 10:25 AM
dogguira dogguira is offline
dogguira is starting off with a positive reputation.
Question thermostat direction
I am driving a 74 F100 with a 390. I pulled the old thermostat last night. It didn't have the round copper do hickey on it. The replacement does. Which direction does the copper piece go?
Old 01-23-2006, 10:45 AM
EricJ EricJ is offline
EricJ is gaining momentum as a positive member of FTE.EricJ is gaining momentum as a positive member of FTE.
the copper piece is the temp sensor it goes in the engine, the point goes towards the radiator.
Old 01-23-2006, 11:02 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
You might want to find out where the rest of your old stat went b4 it jams up somewhere.
Old 01-23-2006, 02:01 PM
Thank you.Any suggestions?
The radiator lines were clear so is the water pump opening.
Old 01-23-2006, 02:24 PM
I've seen a few come apart over the years and I've pulled a couple out of blocks I had apart, but I've never seen one get stuck in the pump or cause any problems, so I wouldn't lose any sleep over it. the only moving part in there is the WP and the inlets are so thin I don't think a very large piece could get to it.
Old 01-24-2006, 09:03 AM
trinogt's Avatar
trinogt trinogt is offline
trinogt is starting off with a positive reputation.
Another good tip is to drill a 1/8 inch hole in the flat area of the stat before installing. It will help eliminate any air in the system, and allows a small amount of flow during the cold starts.
Mark
Correct thermostat 460 PapaBearYuma 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-11-2017 10:21 PM
Copper spray Runningaddict Ford Inline Six, 200, 250, 4.9L / 300 3 12-31-2015 02:36 PM
Where to buy front copper/brass heater core? Navdriver 1997-2006 Expedition & Navigator 10 01-26-2013 09:15 AM
Heater core inlet/outlet...does it matter? Keepin It Real Cooling, Heating, Ventilation & A/C 5 04-09-2007 06:44 PM
Thermostat direction rpatrick 1987 - 1996 F150 & Larger F-Series Trucks 3 03-12-2007 05:54 PM
Tags
1994, 302, 351m, 360, 40, 58, direction, directions, f150, ford, hole, mount, ranger, replacement, superstat, thermostat, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
