gears?
The 3.25 will kill your fuel mileage.
The 302 is a short stroke engine, at 3.00 inches, which develops power at higher RPMs than a long stroke engine. With a 3.25 ratio, you will not be turning enough RPMs to be in the 302's power band, which means you have to give it more throttle. Unless you are doing 85 MPH or higher. Your RPMs need to be in the 2500 - 3500 range (or higher, if you have a "performance" engine) to be of best power value - and the 3.25 will not let you reach that at legal speeds.
Even the later trucks, with fuel injected 302s (5.0 liters) have 3.50 (or close) rear end gear set in them.
With a 351, you can safely go to 3.50, possibly to 3.25. With a 400 or higher, you can easily go to 3.00, and possibly to 2.75. With a 300 six, you can go to 3.25 just fine, because it is a high torque long stroke engine. Both the Ford 300 in-line six and the 460 have nearly 4 inch strokes, making them more suitable for power at the 1800 - 2200 RPM range.
I had a 352 V-8, with a 3.50 rear, and it did 15-18 MPG at 75 MPH. But when I put a 2.75 in it, it was so dogged out that I couldn't start off from a stop sign unless I feathered the clutch. It had a 3.50 inch stoke.
Now I have a 460 in it, and the 3.50 is too low. I will put a 2.75 into it, and it should do just fine - but it is a longer stroked engine designed for low RPM torque, and has way more power than your 302 has.
Mine came with a software package that I bought from Summit. I believe it cost about $80 and also has the virtual engine dyno. I've had it for a year or so and it seems to be quite accurate. The engine dyno part of it allows you to check out a bunch of different engine component combinations and beats the heck out of spending a ton of money on parts then wonder if something else is better. Check out any of the online parts stores, they all offer different software packages. "Real dyno" time around here goes at about $200 per hour......
60'BigBlue
04-14-2006 08:45 PM
cjcathey2002
10-08-2002 10:05 PM
Bushwacker
03-18-2000 10:02 PM
