Any engine specs on 6.4L? - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
Old 01-21-2006, 04:26 PM
thexman thexman is offline
thexman is starting off with a positive reputation.
I don't have much time to get on these forums and I've been searching your threads on the 6.4 but haven't found this:
Are there any engine specifications on the 6.4L yet?
I see it's a twin turbo, but that's all I've learned so far. I also learned from a dealer that the diesel option will be put into explorers (at least, I think that was the SUV they named).
thanks,
X
Old 01-23-2006, 06:36 AM
NickFordMan's Avatar
NickFordMan NickFordMan is offline
NickFordMan is gaining momentum as a positive member of FTE.
No specs yet.
Old 01-23-2006, 06:38 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
nothing has been released yet.
6.4L Codes codes codes!!!! ajmicek 6.4L Power Stroke Diesel 6 02-06-2014 06:04 AM
Need advice - purchasing my first 6.4L F350 wfd2 6.4L Power Stroke Diesel 15 11-21-2011 10:49 PM
Engine Removal Question!! jbenford 6.4L Power Stroke Diesel 17 07-26-2011 07:37 PM
best programer for 2010 6.4L power stroke? bulverde bill 6.4L Power Stroke Diesel 23 04-11-2011 02:26 PM
6.4L vs 7.3L ?? Craig64 6.4L Power Stroke Diesel 54 01-07-2008 12:51 AM
Tags
64, 64l, engine, f150, ford, gas, raptor, spec, specs, stats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
