Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 01-25-2006, 04:29 PM
Torque1st's Avatar
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Someone could run a Desktop Dyno run just for some relative figures.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
Eric
Tips & Tricks FAQ for 335 Series Motors
73-79 FAQ & Info
Garage Forum FAQ
For more info use PM.
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 01-25-2006, 05:14 PM
grclark351 is starting off with a positive reputation.
the chain gets pretty lose and starts a floppin way before 100k! add that stretch slop to your retard factor and it can be significant. what about that though, did trucks ever really get the retarded crank timing sprocket?
__________________
http://www.supermotors.net/vehicles/registry/10950
http://www.supermotors.net/vehicles/registry/10952
http://www.supermotors.net/vehicles/registry/16826
  #18 (permalink)
Old 01-25-2006, 07:30 PM
danlee's Avatar
danlee has a good reputation on FTE.danlee has a good reputation on FTE.
This is a simulation that I ran for someone a while ago. It is a 400+0.030 with 9.1;1 CR, 650CFM carb, dual plane, headers, and an XE256 cam.
Torque = 456 ft-lbs@2000 RPM, 456 t-lbs@2500 RPM, 449 ft-lbs@3000 RPM. HP - 317@4500 RPM.
If I retard the cam 4 degrees, I get:
Torque = 453 ft-lbs@2000 RPM, 450 ft-lbs@2500 RPM, 443 ft-lbs@3000 RPM, HP = 327.
I can't simulate fuel mileage, but I would expect the 'straight up' timing will produce the best mileage.
  #19 (permalink)
Old 01-25-2006, 07:50 PM
can you run that sim at +4? i wouldn't be surprised at all if +4 did better on the mileage, unless of course if the loud pedal was stuck to the floor the whole time the engine was running! the -4 position shows the torque dropping off. more torque, less pressure on the gas pedal.
__________________
  #20 (permalink)
Old 01-25-2006, 08:04 PM
danlee's Avatar
If I run it at +4, I get:
Torque = 457@2000 RPM, 456@2500 RPM, and 448@3000 RPM. HP = 306@4000 RPM.
You might pick up some gas mileage at +4, but watch out for the Dynamic Compression Ratio. The intake valve will close 4 degreees earlier and increase the compression. You could need a higher Octane fuel.
  #21 (permalink)
Old 01-25-2006, 09:54 PM
looks like that one is optimised near "0", maybe it's the 9:1 factor that is negating any improvement at +4. is that with the EGR running? that'd keep mr knock knock down. for Gary in the next post, with stock squeeze the advance might show more improvement?
__________________
  #22 (permalink)
Old 01-25-2006, 09:55 PM
garypettengill's Avatar
garypettengill is gaining momentum as a positive member of FTE.
Danlee, based on what you're getting from you desk top dyno then in my situation, 400ci, =.030 bore, stock compression, edelbrock 3171 manifold, 600 Holley, DEH255 cam and headers, I would be best off to run the +4 on the cam as dynamic compression wouldn't be as much of a factor.
  #23 (permalink)
Old 01-28-2006, 01:37 PM
frdtruckman is starting off with a positive reputation.
years ago i had a 79 bronco 351m and the timing was indeed retarded . i had the engine rebuilt , bored 30 over , with a good valve job and used all eldebrock performer parts in it , double timing chain and gears with the 3 key ways , i installed it at 0 or straight up . 4 barrell intake and 600 4 bbl carb , and cheapo headers , it would really run after that , night and day difference
  #24 (permalink)
Old 01-28-2006, 04:57 PM
I just finished degreeing my new cam. It's an Edelbrock 255DEH and I used an Edelbrock double roller timing setup. I installed the cam at the +4 mark on the crank sprocket when I put it together. Upon degreeing it today the cam is in fact now at a 0 degree valve timing. I guess that means that in fact my 400 was retarded 4 degrees.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
