abs/brake light
Here's Code 9; good luck.
Description
Code 9 is generated when the anti-lock electronic control module detects high RABS sensor resistance. The anti-lock electronic control module will consider the RABS sensor circuit to have a high resistance when it exceeds approximately 3k ohms. The code may also be generated by a failed internal anti-lock electronic control module circuit.
Possible Contributing Base Brake Component/Vehicle Wiring Concerns
l Terminal backout in the anti-lock electronic control module harness connector at Pin 3 or Pin 10
l Terminal backout in the RABS sensor harness connector at Pins A or B
l Anti-lock electronic control module or RABS sensor connectors not fully mated with component
l Open or intermittent open circuit in Circuits 519 (LG/BK) or 523 (R/PK)
Description
MotoStrada
01-02-2015 08:15 PM
bcuz1998
07-30-2013 06:55 PM
Dan [Sac]
09-18-2007 02:19 PM
