C6 Transmission won't shift into 3rd anymore - Ford Truck Enthusiasts Forums
Old 08-31-2001, 06:29 PM
pgiw pgiw is offline
pgiw is starting off with a positive reputation.
I have a 1976 F150 4x4 with a 360 and C6. The truck is mainly used for hauling trash, etc. and often sits for a month or so without regular use. The transmission has always worked OK since I bought the truck two years ago, but when I went to drive is a few weeks ago it would no longer shift into 3rd gear. It had sat idle for about 6 weeks before this. The last time I drove it it didn't have any problems and I've never known it to slip or anything. I checked the fluid level and it seems fine. Not sure about the color since i'm not familiar with automatics, but it doesn't look real dark or smell burnt. I also checked the vacumn hose from the carb and it looks OK, although I didn't try clipping off a few inches to get a better seal. I asked a couple of shops and both said they thought I needed a rebuild and quoted ~$1200. Neither of them actually looked at the truck. I can't see spending a ton of money on this old work truck so I started looking for used C6 but no one in my area has one. The yards all said I was looking at around $250 for an exchange. Is there anything else I can check/try before I replace this thing? I can't believe the tranny just self destructed while sitting for a month or so. Any advice is welcomed! Thanks!
Old 09-01-2001, 07:58 AM
Nathan Nathan is offline
Nathan is starting off with a positive reputation.
Check to see if the kickdown linkage has it stuck in passing mode. There is a plastic hickey down at the tranny kickdown lever that sometimes wears and binds it up.
Nathan
Old 09-01-2001, 08:35 AM
390fe 390fe is offline
390fe is starting off with a positive reputation.
You might also try replacing the vacuum modulator and the entire piece of vacuum hose.
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
Old 09-01-2001, 08:40 AM
jowilker's Avatar
jowilker jowilker is online now
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Old 10-02-2014, 10:51 PM
ogitchida ogitchida is offline
ogitchida is starting off with a positive reputation.
is there any answer to the problem? I seem to have run into the same problem. changed the filter and topped off the fluid. I am not too familiar with the transmission. it is a 79 F150 with factory 400. seems like it is stuck in third. I can shift to 1st and 2nd manually but it is an automatic. I also put a new Transfer Case Shifter in a few weeks ago. the pickup also sat for a while as it was used for garbage hauls. Quite curious of your results.
Old 10-03-2014, 10:31 AM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Check the vacuum modulator and the line that goes to it. Check the line for kinks or other problems, make sure it hasn't come off. If the line checks out, take the line off where it connects to the modulator. If trans fluid leaks out, its bad. If no fluid, it still could be bad. They're simple to replace, disconnect the vacuum line, remove one bolt that holds the clamp in place and the modulator comes out. It has an o-ring seal.
Modulators are identified by the color of the stripe. Pretty much the "go to" one is the black stripe. If they don't show that one in the catalog, go with the green stripe. Avoid the pink stripe. That one is a dual diaphragm version that has two vacuum line going to it. If by chance you have one of these, replace it with one of the other two and use the vacuum line that goes to direct manifold vacuum, cap the other line. When you pull the modulator out, be careful. There is a pin that goes in the modulator. Sometimes it comes out with the modulator, sometimes it stays in the tranny. If it comes out, don't lose it.
strange transmission check engine light issue old german 1987 - 1996 F150 & Larger F-Series Trucks 6 01-01-2017 04:26 PM
where to start looking in a idi E4OD swap BORDERBUM Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 02-02-2016 08:23 PM
Transmission problem zoli Modular V8 (4.6L, 5.4L) 2 09-19-2015 01:10 AM
Newbie Diesel Owner('s Friend) '06 F250 6.0 Randall's Truck 6.0L Power Stroke Diesel 9 01-20-2014 03:13 PM
Transmission occasionally shifting strangely... seebeexee 1994.5 - 1997 7.3L Power Stroke Diesel 8 06-09-2013 10:32 PM
Tags
3rd, 78, c6, color, drive, ford, gear, modulator, passing, shift, sticking, transmission, troubleshooting, windstar, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
