Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 01-18-2006, 10:08 PM
bobadi bobadi is offline
bobadi is starting off with a positive reputation.
Question Holley Carb difference? (auto/standard trans)
There is a 4 barrel Holley on E-bay that was made for an automatic transmition. What is the difference, and can this Carb be used effectively with a standard trans?
__________________
'59 F-100 '59 F-350 '67 N-600
  #2 (permalink)
Old 01-19-2006, 10:56 AM
klatt_89 klatt_89 is offline
klatt_89 is starting off with a positive reputation.
I believe that there is a slight difference.. I'm thinking that carbs on the autos are made to let the engine idle lower, whereas on a manual, you can have the engine idle faster without worries.
Hope this helps, please correct me if i'm wrong.
Dustin
__________________
1999 F-150 SuperCab Long Bed
  #3 (permalink)
Old 01-19-2006, 06:27 PM
312 312 is offline
312 is starting off with a positive reputation.
if its for a ford it will have the hookup for kickdown.
  #4 (permalink)
Old 01-19-2006, 06:39 PM
Quote:
Yes, that does make sense, thanks.
__________________
  #5 (permalink)
Old 01-19-2006, 06:44 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE.
the only difference is the kickdown lever nothing else.
  #6 (permalink)
Old 01-19-2006, 07:26 PM
286merc 286merc is offline
286merc is starting off with a positive reputation.
Any difference is external. Besides the kickdown there is also the dash pot.
__________________
Carl
See my profile for details
  #7 (permalink)
Old 01-20-2006, 02:07 AM
Quote:
Now this is interesting, is the dashpot more heavy duty, so to counter the momentum of the downshift linkage? If so, would it be to slow to return to idle if used with a standard trans?
Hmmmm
Thanks!
__________________
  #8 (permalink)
Old 01-20-2006, 11:22 AM
312 312 is offline
you can adjust or remove them.
  #9 (permalink)
Old 01-20-2006, 12:53 PM
Idle speed on standard tranny is not a big deal, why you have a clutch cause you can rev it up to get going. Why we guys with manuals have hoter cams, we won't have to worry about anything really, just getting it to the rom that it normally can take a load under.
Sorry ifi was wrong on the carb, i'm putting a 650 cfm holley on my 302, it'll wanna load up on me but oh well, best luck with your vehicle.
__________________
  #10 (permalink)
Old 01-20-2006, 07:00 PM
wild.bunch's Avatar
wild.bunch wild.bunch is offline
wild.bunch is gaining momentum as a positive member of FTE. wild.bunch is gaining momentum as a positive member of FTE.
The purpose of the dashpot on automatic trans cars & trucks is to prevent stalling on a quick stop.
At times, when one is driving along and the torque converter is "coupled," and one suddlenly lets off the accelerator and stamps on the brake, the converter remains "coupled" and the engine, which is on the idle stop, will stall. The dashpot stops the throttle blades from closing completely for a brief moment as it "bleeds down," which gives the engine enough gas to stay running until the converter uncouples, allowing the engine to slowly achieve idle without stalling.
__________________
My Little Y Block Page
  #11 (permalink)
Old 01-21-2006, 09:33 PM
Thanx for stepping in Tim, some days I just dont get time to play on here!
The dash pot is a simple add-on affair that is easily removed or simply pop off the link and leave the rest alone for a stick shifter.
__________________
Carl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
