01-18-2006, 08:31 PM
1. Pedastal (non-adjustable) rockers simply torque to 25 ft-lbs. I found no need to turn the engine. I torqued all to spec, turned the engine, rechecked torque and all were right on.
2.yes. It is advisable to leave out the front and rear rubber gaskets and substitute a good quality RTV sealant, as the rubbers will leak in time.
3 I had the machine shop replace the nipple on my block, but I have seen other posts that have a part number for an appropriate store.
__________________
I don't want more power, I want all the power!
