propane tank
A RV horizontal vapor tank can be frame rail mounted or bed mounted. Horizontal tanks are ASME approved which means they can be permanently mounted. They come in all sizes. A 10 x32 is 7.9 gallons and will fit in between the frame rails of the Ford if you want to mount it underneath. Larger diameters such as a 12 x 32 is about 10 gallons so if you go in the bed, you can use one of these.
You can use vertical style tanks with a vapor draw system. They are DOT approved, which simply means they can be transported full or to be filled. Think of every travel trailer/pop up. They have to be mounted upright and secured so that they can't tip over. Mounting them in a vented toolbox for example works well.
Hope this helps!
Hope this helps!
jonnybronco
Bio-diesel, Propane & Alternative Diesel Engine Fuels
03-06-2014 11:27 PM
krol
04-01-2008 10:04 AM
Red460
09-24-2007 10:36 AM
mmmPowerStroke
02-07-2005 07:37 PM
