'67 240 fuel pump problems - Ford Truck Enthusiasts Forums
Old 01-18-2006, 02:25 PM
FOGHAT64 FOGHAT64 is offline
FOGHAT64 is starting off with a positive reputation.
I am having problems with getting fuel to the carb. I have changed the fuel pump, filter. Blew the lines out. When I first start the truck the lines and filter fill up and will idle if choked. When I press the accelerator it empties the line and filter and will not run.
Old 01-18-2006, 05:42 PM
97f3504x4ps 97f3504x4ps is offline
97f3504x4ps is starting off with a positive reputation.
Check the rubber fuel line that goes from the frame to the fuel pump, have had them leak and suck air, thus not delivering enough fuel. If you have the old fuel filter that screws into the carborator these become cloged and not enough fuel to carb bowel to run truck. Its a good idia to replace it even if you can blow threw it, the filter that is. I have poked them threw with a scew driver just to get me home when they become cloged.
good luck.
Old 01-19-2006, 06:50 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome FOGHAT64, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 01-19-2006, 07:57 AM
Thanks for the reply. I will check the line to the fuel pump. I didn't think about that, because I took the output line off the pump and it pumped gas to the inner fender. I have changed to an inline clear filter. I will check all the rubber lines.
Air in fuel system trouble TripTheDog 1973 - 1979 F-100 & Larger F-Series Trucks 8 11-13-2013 10:32 PM
Fuel pump/filter/pressure regulator questions. Myfreeford Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 01-11-2012 11:07 AM
fuel system problems AFoster1025 1997-2006 Expedition & Navigator 6 10-25-2010 06:48 PM
1991 F150 Fuel Pump Won't cut off Won't Start fordf1501991 1987 - 1996 F150 & Larger F-Series Trucks 17 04-30-2008 10:00 PM
Fuel Filter Light On Kennebec 1999 - 2003 7.3L Power Stroke Diesel 1 08-10-2003 09:54 PM
Tags
240, engin, ford, fuel, gas, pump, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
