Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-18-2006, 01:23 PM
Dregsz Dregsz is offline
Garage is empty, add now
Dregsz is starting off with a positive reputation.
2001 7.3 PSD: Do I need to modify truck or can I just pump in the biodiesel?
Hi All,
I read a number of posts on the forum but some get too technical too quiclkly.
If I want to run biodiesel in my 01 Excusion, can I just go and fill up and bring a few extra fuel filters along?
Can I try a half tank mixed into whatever #2 is already in my tank, and switch back and forth depending on what is available, bio or dino, when it's time to fill up?
Do I need to convert the truck before using biodiesel or do I need to make any kind of commitment to run it?
or can I just go back and forth?
THanks
Evan
  #2 (permalink)
Old 01-18-2006, 01:41 PM
willbd willbd is offline
willbd is starting off with a positive reputation.
Quote:
Originally Posted by Dregsz
Hi All,
THanks
Evan
The things you need to consider are....
If the outside temp Below 40* F you want to run a blend like B75
You truck will run fine on B99 if it's over 40* f.
Yes carry an extra fuel filter.
Change your fuel filter after about a week if you run anything over B20
B20 and less should not cause the deposits in your fuel system to release.
Here is a quote form a local oil company about biodiesel.
"Once somebody gets into biodiesel, it's like they discovered Jesus Christ for the first time," said Mark Fitz of StarOil Co. in Portland. "They can't stop talking about it."
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
  #3 (permalink)
Old 01-20-2006, 11:34 AM
anger65 anger65 is offline
anger65 is starting off with a positive reputation.
Sorry if it's been covered, but I'm in the same boat as Dregsz....
I'm reading post after post on this, I do have one question.
How often will you have to changer fuel filters on Bio?
  #4 (permalink)
Old 01-20-2006, 12:32 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Usually, after changing filters once or twice, the "scum" from dinodiesel has been removed from the system. Once the system is clean you can return to normal change intervals. If you are using B-2 or B-5 you should not notice any filter plugging. FABMANDELUX
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
