Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-18-2006, 11:04 AM
61F750 is starting off with a positive reputation.
Which coil for duraspark?
Have 86 f-150, was 302EFI. Am installing stock carbed 302 with duraspark distributor (Cardone 302899) and ignition module (Motorcraft DY893 "blue").
What type of coil is best? Have TFI coil from old 302EFI, and several "can type" coils from different years.
I did a search; still confused. Looking for stock, not high performance.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-18-2006, 04:40 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
You can tell a duraspark coil because it has pins instead of threaded studs for the elect connections. There is a big plastic "u" piece that plugs into it. There are some electrical differences in the coils, so it's a good idea to get the right one.
Make sure you add the resistor in the + coil circuit too.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 01-18-2006, 10:14 PM
OK, I have one of those from an 85 6 cylinder, and can get the resistor wire from the same place. Thanks.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
