Motorcraft 2150 Specs - Ford Truck Enthusiasts Forums
Old 01-17-2006, 08:20 AM
IowaTower's Avatar
IowaTower IowaTower is offline
IowaTower is starting off with a positive reputation.
I need help with a stock 2150. I rebuilt it, now I need to tune it. Except, I can't find any specs for it -- it's not listed in Chiltons or Haynes manuals I have for my '79 F150 4x4, nor the Mitchell manuals for Ford cars that used the 351M. The best info I can find is "if it isn't listed here, check the VECI label on your hood" -- which doesn't have all the calibration info for it, either. Those books list 21 kabillion other flavors of 2150, but not mine - and the specs differ so much, I can't even begin to guess.
Choke pulldown setting, dechoke setting, fast idle, curb idle, dashpot clearance. No A/C, No TSP.
The only ID on the carb itself is on the plate in front of the choke-housing: NIT on one line, and D9TE-AMB on the next.
The VECI label says D9TE-9C485-ATB and off in the corner, AKA.
List of acronyms used here on FTE Kwikkordead 1999 - 2003 7.3L Power Stroke Diesel 17 04-27-2016 04:10 PM
Mudstock '06 SwOkcOffRoader Offroad & 4x4 4 07-12-2006 11:29 PM
The Engine FAQ Thread Brad Johnson Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 02-18-2006 12:39 PM
1998 Ranger 3.0 to 4.0 engine swap. Easy?? Brilac Ranger & B-Series 5 12-22-2005 11:28 PM
Removing a vacuum shift motor on a 1998 F-150 elmo2002 Clutch, Transmission, Differential, Axle & Transfer Case 4 12-20-2005 05:33 PM
Tags
2150, amb, carb, choke, clearance, d9te, for, ford, label, labels, motorcraft, nit, specs, tsp, veci
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
