Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-16-2006, 01:15 PM
koldstart koldstart is offline
koldstart is starting off with a positive reputation.
Arrow Bought it! 93 Ranger 4x4! Now we fix.
-1993 Ford Ranger XLT
-4.0 A4LD Trans
I had posted a thread a while back, about a truck that I was contemplating on purchasing, because It had a few issues but ended up with it in my driveway!
Soo.. Now I can give some more specifics on the problems I need hammered out.
--4 Wheel drive -- I know, I know, there are tons of these threads floating throughout the forum, but unfortuntely all that I have seen; I don't really follow.
--> So I have no power to the 4x4 Button or the Low Range Button, No lights, grinding, or even clicking. I have went as far as exaiming the 4 Wheel Drive module behind the drivers seat with instrucitons through peiced together threads. I got 4 Flashing pulses from the LED which, rumor has it means power is going to the module and it is NOT defective and the problem is further down the line. Need Help! Unsure what is the next diagonistic step. Callin out the pros once more.
  #2 (permalink)
Old 01-17-2006, 12:37 AM
rangerboy21's Avatar
rangerboy21 rangerboy21 is offline
rangerboy21 is starting off with a positive reputation.
Control Module Circuits
There are three wiring connectors connected to the electronic control module: the eight-wire pigtail harness connector; the five-wire harness connector; and the eight-wire harness connector.
To check the integrity of these circuits, disconnect the harnesses from the electronic control module and perform the following checks.
Eight-Wire Pigtail Harness Connector
1. Connect a voltmeter between terminal 8 and ground. The voltmeter should indicate battery voltage at all times.
2. Connect a voltmeter between terminal 7 and ground. Then turn the ignition switch to the RUN position. The voltmeter should then indicate battery voltage.
CAUTION:
In the following sections where the usage of an ohmmeter is specified, always remember that an ohmmeter should NEVER be connected into a "live" or powered circuit. If the ohmmeter is subjected to a powered circuit, severe damage will be done to the meter. The vehicle's battery should be disconnected before performing checks on any circuit with an ohmmeter to prevent any accidental damage to the meter.
3. Connect an ohmmeter between terminal 6 and ground. The ohmmeter should indicate a low resistance value (less than 10 ohms).
4. Connect an ohmmeter between terminals 4 and 5 of the wiring harness connector. The ohmmeter should indicate a low resistance value (less than 10 ohms).
5. Connect an ohmmeter between terminal 3 and ground. The ohmmeter should indicate zero ohms.
6. Connect an ohmmeter between terminal 2 and ground. The ohmmeter should indicate zero ohms.
Five-Wire Harness Connector
1. Connect an ohmmeter between terminals 1 and 2. Then depress the 4x4 (2H-4H) switch. The ohmmeter should indicate a low resistance value (less than 50 ohms) while the switch is being depressed.
2. Connect an ohmmeter between terminals 1 and 3. Then depress the LOW RANGE switch. The ohmmeter should indicate a low resistance value (less than 50 ohms) while the switch is being depressed.
3. Connect a test lead between terminal 4 and ground. Turn the ignition switch to RUN and observe the indicator lights. The LOW RANGE light in the instrument panel and LOW RANGE indicator light on the switch should illuminate.
4. Connect a test lead between terminal number five and ground. Turn the ignition switch to RUN and observe the indicator lights. The 4x4 light in the instrument panel and 4x4 light on the switch should illuminate.
Eight-Wire Harness Connector
1. Connect an ohmmeter between terminal 1 and ground. On a vehicle equipped with a manual transmission, depress the clutch pedal and observe the ohmmeter. The ohmmeter should indicate a low resistance (less than 50 ohms) while the clutch pedal is being depressed. If the vehicle is equipped with an automatic transmission, shift the transmission into NEUTRAL and observe the ohmmeter. The ohmmeter should indicate a low resistance (less than 50 ohms) while the transmission selector lever is in the NEUTRAL position.
2. Connect an ohmmeter between terminals 2 and 3. The Ohmmeter should indicate a low resistance reading (225-275 ohms). This will check the continuity of the speed sensor that is located in the transfer case. The speed sensor picks up the rotating speed of the transfer case rear output shaft from two notches that are cut in opposite sides of the outer ring of the clutch housing assembly.
__________________
1993 Ranger STX 4.0L 4x4
1987 Ranger XLT 2.9L 4x4
  #3 (permalink)
Old 01-17-2006, 08:53 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE. Ken00 is gaining momentum as a positive member of FTE.
Nice post, I'll have to add this to the tech info thread.
__________________
Ken
X Ranger, BII & NJ Chapter Moderator
2000 XLT Sport SC 3.0
2002 XLT Std Cab Long Bed 3.0
1989 Custom Std Cab Short Bed 2.9
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
