Blowing fuse #13 (abs)
I keep blowing fuse #13. Had a brake job done 2 weeks ago. Everything was fine until this weekend, could not get truck out of Park. checked fuse 13,blown. Replaced it, fixed my problem but now it keeps blowing. There is some ozzing of brake fluid anround the master cylinder switch (98 f150 4.6l 2wd). Any ideas what is causing the fuse to blow? Thanks
could be your master cylinder is leaking into your cruise switch control does cruise work? there is a recall about this. try un hooking your cruise switch it is a plug in at the front of the master cylinder. if this works leave it unplugged and get to the dealer as soon as possible. Could cause a fire if left plugged in.
