1999 Superduty no brake lights; also trailer brake controller problem
Hello all. 1999 F250 Super Duty.
I was towing my trailer tonight, everything working fine, then I noticed that when I stepped on the brake pedal, the trailer brake controller indicator light did not turn from green to red (as it usually would).
I figured a wire came loose on the trailer, but when i got home, I discovered that I have no brake lights at all, including the third brake light omunted on the cab. Even with the trailer disconnected, nothing.
I still have turn signals and running lights. I looked at all the fuses (especailly 20A fuse #13 under the dash) and looked at the fuses in the power distribution box. They all look OK.
I guess I will try and get it looked at tomorrow morning, but thought I would see if you guys had any suggestions first.
As always, THANKS VERY MUCH!!
-Mike
-Mike
jeepclark
1997-2006 Expedition & Navigator
02-25-2012 03:14 PM
