clutch pedal
Old 01-15-2006, 09:25 PM
99FordF350's Avatar
99FordF350
99FordF350 is offline
clutch pedal
pedal goes to floor and stays there is this the slave or the clutch?
thanx
Old 01-16-2006, 01:22 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
Usually it's a problem with the hydraulic system, could be the clutch master or slave. If the pedal's on the floor, is the clutch still engaged? What happens if you manually pull the pedal back up? Does it stay up on it's own, and when you press it to the floor again is there normal clutch resistance, or does it just drop easily?
AJHEATING
04-15-2022 10:29 AM
nassi
04-22-2014 05:12 PM
Schmitty
09-23-2010 09:09 AM
hitecdan
12-10-2002 06:26 PM
Quick Reply: clutch pedal
