351M Cutting out when warm
My bone stock 351M keeps dying on me when it warms up. It has new plugs/wires/distributor/fuel filter so those are all fine. I thought it was the choke so I installed a manual choke but that wasn't it.
It runs great most of the time but sometimes when I'm crusing down the highway it starts sputtering and backfiring then it usually dies. It will fire right back up but when I take off it does dies again. It will idle fine but when I start going it acts like it is choking out or running out of gas.
Any thoughts would be greatly appreciated. Thanks
Those sound like the same symptoms I had three weeks ago. I had the 351m and probably the original carb that had been rebuilt at least once. Something inside my choke broke for sure, and not sure if anything else broke in the carb or not. I just went to my local autoparts store and got a rebuilt Motorcraft 2bl carb. That fixed it.
I had the same problem on my truck a while back. I found a warped gasket where the carb and the egr plate meet. I figured it was affecting the vacuum so i put a 1inch plate and new gaskets on hasnt done it sence. So you might want to check that and also make sure you floats are set right.
Hope this helps Chase
1979 F-250 4x4
460 Holley650, MSD OFFROAD
C6-B&M Transpack
Dana HD44Front/60Rear 3.73 Limited Slip
35 inch Goodyear Implement Tires
4 inch Skyjacker System
Going to be souped up soon
1979 F-250 4x4
C6-B&M Transpack
