Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered Bonus Built, Classic and Box Style Ford Trucks
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-14-2006, 06:08 PM
klatt_89 is starting off with a positive reputation.
Lowering Front End on '57
I was wondering how i could lower the front end of my 1957 F-250, it set too high for my tastes. Any idears on how to do this?
thanks
Dustin
__________________
2001 Pontiac Grand Am GT!
1957 Ford F-250!-390 FE-Project Truck
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-14-2006, 10:16 PM
After they're outa the truck, use big c clampst to hold the pack together, then gently release the pressure with the clapms, if hte springs don't have a clamp that holds thim in plcae, you need to clam them before you take them out, use c clamp when losening flip the bototm spring, take the 2nd out, & they will stick down, you can clamp them and squeeze them up and u bolt it back if it sticks down too much, you can do that after you get it back together and put the center bolt back in
Anyting else to add to his?
Thanks
__________________
  #3 (permalink)
Old 01-15-2006, 12:02 AM
kdmcinnes's Avatar
kdmcinnes is starting off with a positive reputation.
Might look into a dropped axel if you are running stick.
Kyle
__________________
This is not a hobbie, It's a lifestyle!
  #4 (permalink)
Old 01-15-2006, 12:42 AM
How much would a dropped axel cost.
Yeah, i'm running a MerCruiser 302 with a M5OD tranny, so i'm running stick anotherwards.
Dustin
__________________
  #5 (permalink)
Old 01-15-2006, 03:58 AM
Brian_B's Avatar
Brian_B is starting off with a positive reputation.
I am guessing he meant stock (as in front suspension). Hence, the dropped axle. I think they run around $250-300 for them, but I am not real sure. If I get up and go get catalogs right now, I will probably not make it back to the computer room.
I am sure you can remove some leaves, but I do not know the procedure for your year.
I am extremely sleepy , so I am not finding much.
You might look at this thread:
http://www.ford-trucks.com/forums/sh...d.php?t=356235
I am seriously considering the aerostar IFS for mine, but thats a lot of fabrication without the right tools.
__________________
Editorial removed from sig.
  #6 (permalink)
Old 01-15-2006, 09:47 AM
kdmcinnes's Avatar
Taking out leafs would work, but like on mine I am running a 351 W and the oil pan right now is only about 1 inch above the axel, so I cant take out any leafs because of clearence-My option is a drop axel wich will lower about 3 inches without having to do a whole clip, And I like the stock ride, I think she rides like a caddy-So really it depends on a number of factors. Mid Fifty has drop axels listed for $369.00 I am not sure if that is for a 57 or not I know 53 thru 56 they will work.
Kyle
__________________
  #7 (permalink)
Old 01-15-2006, 05:42 PM
pootscratch89's Avatar
pootscratch89 is starting off with a positive reputation.
You could also install mono leaf springs--but measure carefully; it might lower it more than you really want...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
