2000 Ranger Wiring Diagram - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-14-2006, 05:48 PM
mrblonde mrblonde is offline
mrblonde is starting off with a positive reputation.
I've got a 2000 Trailhead Ranger, 3.0 engine, 2wd. I had major corrossion in connector c309, which is located under the driver's seat. This caused several codes, and no signal from the RABS sensor. Anyway, while taking care of this problem I must have reconnected some wires incorrectly. Does anyone have a diagram for this connector, or maybe what diagram I should ask for at the dealer? Thanks in advance.
Old 01-14-2006, 06:53 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Welcome. The best I can do for you is this:
The RD/PK (pin 17) and the LG/BK (pin 21) wires are for the rear ABS speed sensor.
HTH
Old 01-14-2006, 06:58 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Rock got to it first.
Old 01-15-2006, 12:26 PM
Thanks a lot guys. You wouldn't be able to get your hands on the diagram for the male half of the connector, would you?
Old 01-15-2006, 08:37 PM
Ken00's Avatar
The wire colors are the same on the male side, the pins are switched side to side, pin 1 is pin 6 and 6 is 1.
Old 01-16-2006, 06:59 PM
Oh, OK, thanks again guys
1994 f250 connector c103 diagram BearFootCustom 1987 - 1996 F150 & Larger F-Series Trucks 4 07-18-2016 09:24 PM
2000 ranger wiring problems madizon1420 Ranger & B-Series 1 04-15-2016 07:36 PM
Need 2001 F-150 Radio connector pinout diagrams Adam Baker Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 07-24-2012 10:48 PM
2000 Ranger wiring issues sixstringsamurai Ranger & B-Series 2 11-09-2008 11:03 AM
Serpentine belt diagram starquest Ranger & B-Series 10 07-22-2006 05:21 PM
Tags
2000, 30l, diagram, engine, free, ranger, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
