1958 VIN/Color Code - Ford Truck Enthusiasts Forums
1958 VIN/Color Code
Old 01-14-2006, 03:15 PM
2bocat's Avatar
2bocat 2bocat is offline
2bocat is starting off with a positive reputation.
1958 VIN/Color Code
Neighbor just received (free!) a 1958 F-100. We towed it home and checked the VIN. VIN: F10C8R30355. I've searched enough of the archives to decode most of VIN and such, but two questions remain:
1) Tag in glovebox door has CLR N stamped in it. I assume this is the color code, but what does "N" stand for?
2) The 292 that's in it, is actually only partially in it. A previous owner tore the heads and top of the motor off and left them in the cab for many years. I always wonder how this happens...but anyway - The hood's been closed, and we're in the desert, so there may be a chance the original motor can be rebuilt. My question is, in 1958, was there such a thing as a "numbers matching truck"? Is there a serial number stamped on the engine block that matches a serial number stamped on the frame? If so, can you tell me where to scrape the grime away and look for both?
Thanks much!
Glenn
Old 01-14-2006, 04:54 PM
kooper909's Avatar
kooper909 kooper909 is offline
kooper909 is starting off with a positive reputation.
I believe the "C" in the VIN number indicates a 292 V8.
Post your VIN and data plate info in the "57-60 Registry" thread and they'll decode everything for you.
Old 01-15-2006, 01:13 PM
Earl's Avatar
Earl Earl is offline
Earl has a good reputation on FTE.Earl has a good reputation on FTE.Earl has a good reputation on FTE.
I don't see an "N" color code - can you post a photo of the rating plate so we can see the entry?
As far as serial number matched engines, that didn't start until some time later. You can put just about any 292 in the truck and nobody could tell that it wasn't the original engine.
Old 01-15-2006, 01:18 PM
2bocat's Avatar
Thanks George - that's a big help given the current condition of the engine. Do you happen to know what colors the block/intake/air cleaner etc were on that motor originally? I see yours has alot of bright yellow involved.
I'll post the rest in the registry post. The "N" I'm referring to isn't part of the VIN. It's down below the VIN with the other numbers engraved.
Thanks again,
Glenn
51 F4 VIN versus Cowl stamp numbers? Jolly Roger Joe 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 11-07-2016 11:35 PM
1958 F100 Paint Code Boon 1957 - 1960 F100 & Larger F-Series Trucks 1 04-17-2015 07:03 PM
2nd vin number location for 1956 truck chassis Psmith1951 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 05-09-2014 12:13 PM
1958 F-100 mont974x4 Vehicles for Sale 5 04-20-2014 10:48 PM
Cowl Vin Tag stamping numbers on new plate Question on Stars jmadsen 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 11-21-2013 07:30 AM
Tags
1958, f100, ford, plate, tag, trucks, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
