**quick question** 2000 f150 4x4 front axle bolt size - Ford Truck Enthusiasts Forums
Old 01-13-2006, 05:06 PM
bremen242's Avatar
bremen242 bremen242 is offline
bremen242 is gaining momentum as a positive member of FTE.bremen242 is gaining momentum as a positive member of FTE.
I am getting ready to change one of my front wheel bearings on my '00 F150 4x4 xcab.
I need to know the socket size for the big bolt that holds the CV axle shaft in the wheel bearing.. I know it is bigger than 1-5/16" (have one of those wrenches from doing balljoints), and I figure it is metric. 32mm 34mm ??
thanx..
oh btw, does anyone have the part number for the rear abs sensor on the top of of a 9.75" axle?? mine is reading open and I need a new one.. or what is the technical name for it?
Old 01-13-2006, 06:09 PM
firefytr29wfd's Avatar
firefytr29wfd firefytr29wfd is offline
firefytr29wfd is starting off with a positive reputation.
I believe it is a 36mm, maybe a 34mm.
Dont exactly remember from when i did my ball joints
12mm or 14mm wheel Studs Gage2502 Expedition & Navigator 11 06-29-2013 04:25 PM
Front wheel bearing replacement KiwiFord 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-14-2010 06:20 PM
Standard Bolt Sizes On 2004-2008 F150s? HankMurphy 2004 - 2008 F150 5 05-01-2009 11:52 AM
Tools for frt wheel bearing change 99 f150 msmmce1 1997 - 2003 F150 3 11-14-2007 03:11 AM
Axle nut size Swampwater 1997 - 2003 F150 1 04-11-2003 06:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
