Cruise control update
I just bought the kit with the new switch and harness for $25 bucks and put it in myself. Took about 10 minutes. No problem. Better than the recall that doesn't change the switch. I hear the whole idea was just to get owners to come back to the dealership with their trucks in the hope that they would decide that was a good place for service.
Could someone post a picture of what the completed fix looks like. I brought my truck into a Ford dealer down in Florida (live in Chicago) and they went ahead and fixed it for me.
But when I opened the hood when I got back to my place there is something with twisty-ties and what looks to be electrical taple wrapped around something. Dont know if this is what its supposed to look like, so a picture from someone one help.
Thanks
Thanks
I received my notice about a month ago stating the parts would not be available now until February...but I also just called the dealer and he has the parts in stock. Don't believe everything you read. Call your dealer. I'm getting mine done today at lunch.
4Trax...why is it you feel that Ford is not doing it right? A fuse that blows in case of probs is pretty standard for any electrical circuit. Just my opinion, but I would rather have a fuse to replace instead of a harness, switch or the way these are designed, the master Cylinder.
#29
I dont know of a way to check it unless someone else chimes in. If you don't get anything, try starting another thread for that. Maybe it will get someone attention that has the answer....sorry. That or see if one of your friends that has the same setup for the cruise will let you swap just to check it.
#30
Originally Posted by Ice Cold
Do you think the dealer would give me the kit and let me install it? Don't really like other mechanics touching my vehicles.
Still waiting for Ford to announce the part is in stock, I don't really care since I regularly check the connection to make sure its dry.
I don't like others working on my truck either, I live in Pennsylvania which has a annual inspection and they pull the wheels to check the brakes. I have to retorque the lug nuts every time, they always overtighten the lugs. Also the center caps are usually not replaced properly.
