Dual Mass flywheel problems on 1992 F250
Old 01-13-2006, 09:18 AM
04hdchick's Avatar
04hdchick
04hdchick is offline
Unhappy Dual Mass flywheel problems on 1992 F250
Truck at repair shop to have clutch replaced and was advised need new flywheel. Apparently it is this dual mass flywheel and can't be "turned". Anyway, I've done some research and have some questions. First, found info on LUK conversion. Anyone used this? Good, Bad? Can I just get the flywheel or do I have to use the entire kit? Also, have been told have 11 inch clutch or a 12 inch clutch. Will 12 flywheel hook up to 11 inch, howabout 13 inch to a 12? If I decide to stay with dual mass flywheel, any ideas on where I can get one for less than $800?
Old 01-13-2006, 10:47 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,102 Likes on 2,164 Posts
i would go with the luk unit. the dm flywheel will only fail again, and for the price of a dm flywheel, you can get a complete luk setup.
Old 01-13-2006, 11:58 AM
libsys's Avatar
libsys
libsys is offline
Do some searches on this site and others, and you will get a variety of opinions. Lots of folks have gone with the LUK setup. Biggest complaint with it seems to be gear rollover noise. Personally, I didn't want to take the chance. I got a new DMF kit (flywheel, disk & pressure plate, pilot and throwout bearing) from South Bend Clutch for around $850.
Old 01-13-2006, 12:38 PM
fellro86's Avatar
fellro86
fellro86 is offline
I helped a friend put a Luk in his father's 94, the cost was well under half of what he could get the dual mass for. I never noticed any noise, and they never said anything. BUt his dad got back after we put that in, and he acme up to me kinda like pissed off, and said "what did you do to my truck?" Of course I didn't know what he was talking about, and he then let me off the hook saying" I t has more power than it ever did!" He was just kinda picking on me. The Luk flywheel has some more mass to it, so the torque it gives gives the impression of more power.
Old 01-14-2006, 10:10 AM
wh336fire's Avatar
wh336fire
wh336fire is offline
I put a luk in my wifes truck , works great . Pulls great and is easier on the leg muscles .
Old 01-14-2006, 12:21 PM
cookie88's Avatar
cookie88
cookie88 is offline
Welcome to Ford Truck Enthusiasts and the diesel forums 04hdchick.
What I like the best about my LUK conversion is the pedal effort required is significantly less than stock. It has a very light, very fast "sports car" sort of feel to it. That, and the full repset with the new flywheel costs about the same as just a replacement clutch kit from Ford.
Old 01-14-2006, 12:46 PM
Dieseldan7.3's Avatar
Dieseldan7.3
Dieseldan7.3 is offline
My stock dual mass flywheel was the stiffest piece of **** clutch Ive ever used. LuK singlemass is like pushing on a pillow and it locks up just fine. In 1st and reverse it has a whine but that is normal. Even clutches on some powerstrokes do that too. Best 700 dollars I spent on my vehicle.
Old 01-14-2006, 05:11 PM
bluthunder's Avatar
bluthunder
bluthunder is offline
what is the advantage of the dual mass to begin with?
Old 01-15-2006, 12:20 AM
fellro86's Avatar
fellro86
fellro86 is offline
It was supposed to reduce driveline vibration....
Old 01-15-2006, 08:23 AM
shorthair's Avatar
shorthair
shorthair is offline
lucky larue has a mod to your DM for under 20$ that makes it work like a luk single mass. search other sites for more info.
andrew78
07-30-2015 02:54 PM
PAVEMENTMAN
16
09-09-2009 06:07 PM
quality1const
16
05-23-2008 09:24 PM
redstrawbarry
12-21-2006 06:34 AM
MR_J_DAHMER
11-29-2005 12:16 PM
Quick Reply: Dual Mass flywheel problems on 1992 F250
