Dual Mass flywheel problems on 1992 F250 - Ford Truck Enthusiasts Forums
Old 01-13-2006, 09:18 AM
04hdchick 04hdchick is offline
04hdchick is starting off with a positive reputation.
Unhappy Dual Mass flywheel problems on 1992 F250
Truck at repair shop to have clutch replaced and was advised need new flywheel. Apparently it is this dual mass flywheel and can't be "turned". Anyway, I've done some research and have some questions. First, found info on LUK conversion. Anyone used this? Good, Bad? Can I just get the flywheel or do I have to use the entire kit? Also, have been told have 11 inch clutch or a 12 inch clutch. Will 12 flywheel hook up to 11 inch, howabout 13 inch to a 12? If I decide to stay with dual mass flywheel, any ideas on where I can get one for less than $800?
Old 01-13-2006, 10:47 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i would go with the luk unit. the dm flywheel will only fail again, and for the price of a dm flywheel, you can get a complete luk setup.
Old 01-13-2006, 11:58 AM
libsys libsys is offline
libsys is starting off with a positive reputation.
Do some searches on this site and others, and you will get a variety of opinions. Lots of folks have gone with the LUK setup. Biggest complaint with it seems to be gear rollover noise. Personally, I didn't want to take the chance. I got a new DMF kit (flywheel, disk & pressure plate, pilot and throwout bearing) from South Bend Clutch for around $850.
Old 01-13-2006, 12:38 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I helped a friend put a Luk in his father's 94, the cost was well under half of what he could get the dual mass for. I never noticed any noise, and they never said anything. BUt his dad got back after we put that in, and he acme up to me kinda like pissed off, and said "what did you do to my truck?" Of course I didn't know what he was talking about, and he then let me off the hook saying" I t has more power than it ever did!" He was just kinda picking on me. The Luk flywheel has some more mass to it, so the torque it gives gives the impression of more power.
Old 01-14-2006, 10:10 AM
wh336fire wh336fire is offline
wh336fire is starting off with a positive reputation.
I put a luk in my wifes truck , works great . Pulls great and is easier on the leg muscles .
Old 01-14-2006, 12:21 PM
cookie88's Avatar
cookie88 cookie88 is online now
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Welcome to Ford Truck Enthusiasts and the diesel forums 04hdchick.
What I like the best about my LUK conversion is the pedal effort required is significantly less than stock. It has a very light, very fast "sports car" sort of feel to it. That, and the full repset with the new flywheel costs about the same as just a replacement clutch kit from Ford.
Old 01-14-2006, 12:46 PM
Dieseldan7.3's Avatar
Dieseldan7.3 Dieseldan7.3 is offline
Dieseldan7.3 is starting off with a positive reputation.
My stock dual mass flywheel was the stiffest piece of **** clutch Ive ever used. LuK singlemass is like pushing on a pillow and it locks up just fine. In 1st and reverse it has a whine but that is normal. Even clutches on some powerstrokes do that too. Best 700 dollars I spent on my vehicle.
Old 01-14-2006, 05:11 PM
bluthunder bluthunder is offline
bluthunder is starting off with a positive reputation.
what is the advantage of the dual mass to begin with?
Old 01-15-2006, 12:20 AM
fellro86's Avatar
It was supposed to reduce driveline vibration....
Old 01-15-2006, 08:23 AM
shorthair shorthair is offline
shorthair is starting off with a positive reputation.
lucky larue has a mod to your DM for under 20$ that makes it work like a luk single mass. search other sites for more info.
Dual mass or single mass flywheel andrew78 1994.5 - 1997 7.3L Power Stroke Diesel 3 07-30-2015 02:54 PM
300 ZF swap clutch question mutant Ford Inline Six, 200, 250, 4.9L / 300 7 06-12-2014 08:07 PM
Dual mass flywheel or single ??????? PAVEMENTMAN 1994.5 - 1997 7.3L Power Stroke Diesel 16 09-09-2009 06:07 PM
Dual Mass Flywheel Or Solid Flywheel ? quality1const Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 05-23-2008 09:24 PM
390 to 428 clutch, flywheel trans questions MR_J_DAHMER 1967 - 1972 F-100 & Larger F-Series Trucks 4 11-29-2005 12:16 PM
Tags
1992, 69diesel, 73, automatic, diesel, dm, dual, f250, flywheel, ford, kit, lnoise, luk, mass, problems, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
