Pullrite Super Glide 5th, good? - Ford Truck Enthusiasts Forums
Old 01-13-2006, 08:43 AM
Kep4's Avatar
Kep4 Kep4 is offline
Jäger
Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.
I'm buying a 5th wheel this spring. I've researched hitches and like the Super-Glide because of the automatic slide feature. Anybody here have one? How do you like it's performance?
Thanks,
Russ
Old 01-13-2006, 10:30 PM
tomaslee tomaslee is offline
tomaslee is starting off with a positive reputation.
Pullrite
I have a 16 K Pullrite Super Glide with the super rails. Don't know if you are up to speed on those items or not but I like the setup a whole lot! I don't ever have to worry about hitting the cab with the trailer. Second time out I was backing the trailer into a spot in a RV park that was a tight fit. Wife was spotting for me and a "helpful" guy came up in a hurry saying "he's going to hit the cab!" My wife just calmly replied "I don't think so", knowing full well that it was impossible. I have the sort box and it is very very nice knowing that hitch is going to do the sliding for you. Also the super rail mounts allow the bed to be flat and flush in case you want to haul plywood or anything else that requires a smooth bed. I highly reccomend the set up even though it is expensive.
PM me if you have more questions. Tom
Old 03-28-2006, 10:54 PM
Hayman4353 Hayman4353 is offline
Hayman4353 is starting off with a positive reputation.
Smile Pullrite SuperGlide 16000lbs
What did that hitch set you back? I want one just like it for my F-350 Short box. Hayman4353
Old 03-29-2006, 09:37 AM
Thats the part you probably don't want to hear about. I bought the hitch off the internet from Big discount RV and I paid $1,256 for the 16K superglide hitch. There are three different mounting rails and I decided if I was crazy enough to shell out big bucks for the hitch I would do it up right and go with the "super rail" mounts because when they are not in use you simply pull 4 pins and the bed is flat with nothing showing above flush. At the time I was using the truck as a work pickup and that appealed to me. The super rails are the most expensive mounts and I think I paid a little over $500 for them; so guts, feathers and all I laid out about $1,750.
Expensive? You darn right, but I have this thing about seeing something that I judge to be head and shoulders above other products and it fills a need that I have (a short box truck with no danger of hitting the cab) I just go for it. Thats a decision everyone has to make on their own; I personally am quite happy with the decision. Once you put it in you just don't give a thought to your fifth wheel hitting the truck cab. Ain't gonna happen!
Incidently I installed it myself and its not that difficult. Just measure, re-measure, and then go get a cup of coffee and measure again. It's hard to screw it up if you follow their instructions. Hope this helps!
Old 03-29-2006, 12:51 PM
Thumbs up Pullrite SuperGlide 5th Wheel Hitch.
I know what you are saying is true, I just wanted to know where I could save a buck or two. Appreciate the info. Hayman4353
Old 03-30-2006, 08:32 AM
Yukon Yukon is offline
Yukon is starting off with a positive reputation.
Do you have to be straight on to a Superglide when you hook up or unhook? Or can you be at any angle like a Reese?
Old 03-30-2006, 08:50 AM
I can be at any angle,but I don't own a 5th yet, trying to work a deal,but know I want a Pullrite SuperGlide Hitch. Hayman4353
Old 03-30-2006, 10:13 AM
"ANY" angle is a pretty broad statement. You need to be pretty straight to hook up. I think Pullrite says you need to be within 16 degrees of straight on. Un-hooking I think you could get by with a little more angle than that. If you understand how the Pullrite works then you will understand why you need to be fairly straight. They have a free video available from thier website at http://www.pullrite.com/superglide.htm
Old 03-30-2006, 10:27 AM
That is exactly why I asked the question. It's a great concept, but I know I have backed in some tight spots with my 5er that the truck and trailer were not able to be straight on when I got in it's final spot. Just something for a potential buyer to consider.....
Old 03-30-2006, 01:09 PM
Thumbs up Pullrite SuperGlide 16k Hitch
I'm not resricted I can back in straight,where I have my current trailer there will not be a problem, I really appreciate the info especially the one on tight RV spots. Hayman4353
Old 03-30-2006, 04:40 PM
Toyman's Avatar
Toyman Toyman is offline
Michigan Chapter Ldr
Toyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputation
The hitch is great, the mounting system is great, the whole idea is great. The only problem I have seen is they are expensive, and very heavy. Hard to install and remove by 2 people.
Toyman
Old 03-30-2006, 05:02 PM
This what I have heard,it makes one wonder why we want to put the
superRail Kit on if it's too heavy lift off. Hayman4353
Old 03-31-2006, 08:43 AM
The heavy part is not the super rail kit. The heavy part is the sliding mechanism hitch itself. By the way you can easily take the hitch/super rail apart into three seperate peices; the rails have four pins that seperate them from the hitch sliding assembly and the head of the hitch comes off with just two pins. As far as it taking two people to install it; I install it and remove it by myself but I also have an overhead hoist and I made a small lifting 'jig' that makes a good place to attach the hook on a hoist. It then let the hoist down and set the whole assembly on a small dolly (like a furniture dolly) and roll it around to where ever I want it. Becuase I have the hoist I don't take anything apart but just pull the four pins that attach it to the truck frame and lift it all out at the same time.
Old 03-31-2006, 01:08 PM
That sounds just like the way I remove my hitch. Sure is a lot easier on the back. Put my hitch in the truck this morning and gonna get the 5er out of storage on my way home. Kinda early for Michigan weather but I just can't wait anymore!
Old 03-31-2006, 02:16 PM
I'm scheduled to have a 16K PullRite SuperGlide installed Thursday of next week $2500.00 installed with Super Rail Kit. Another $150.00 for electrical in bed 7 plug. What do you all think? Did I get raped? I live in Fl I guess they thought I was a Snow Bird. I will remove it with my tractor front end loader, the whole thing at one time.Appreciate your post! Hayman4353
Fifth wheel bed mount hole cover / pucks CA-F250 6.7L Power Stroke Diesel 20 11-11-2016 02:07 AM
Mounting for 5th wheel hitch Jace2016 2017 Super Duty 27 10-28-2016 08:34 AM
No acceleration Dad&Son&F100 1961 - 1966 F-100 & Larger F-Series Trucks 8 04-21-2015 10:59 PM
5TH wheel hitch Poll RPARKER559 6.7L Power Stroke Diesel 23 01-14-2011 06:38 AM
Telescoping mirrors stuck aughtx 1999 to 2016 Super Duty 8 07-24-2003 10:52 PM
Tags
16k, autoslide, dealers, edmonton, glide, hijacker, hitch, hitches, problems, pullrite, rails, reviews, slide, super, superglide
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
