Reverse lights fuse 26 blowing
#31
#32
Also try removing the rear back up lamps & see if the fuse pops. If not then the problem is around the lamp socket, or with one or the other lamp.
If it still pops with the back up lamps removed, then it sems to me, the problem is between the switch on the transmission & the rear back up lamp sockets.
Just some additional trouble shooting thoughts to ponder.
