I Beam Help? - Ford Truck Enthusiasts Forums
I Beam Help?
Old 01-12-2006, 08:24 PM
73FOMO's Avatar
73FOMO 73FOMO is offline
73FOMO is gaining momentum as a positive member of FTE.
I Beam Help?
In the process of my rebuild I took the I beams off and rebuilt the kingpins, new busings, the works. Problem is I didn't mark which beam was front beam and which was back. I have put back together with Beam marked DTA-8-TA in the front with the passenger side knuckle. The rear beam is marked DTA-9-TA with the driver side knuckle. Did I assemble these back correctly? Help?
Thanks!!
Old 01-12-2006, 08:29 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
both i beams are identical and interchange.
Old 01-12-2006, 08:54 PM
73FOMO's Avatar
I'm taking your word for it....Thanks Gas Hog! Sure, didn't want to have to change. I was thinking that each beam would have differnt caster settings and would be off if I had put the knuckles back on the wrong beams. If anyone thinks Gas Hog is wrong please let me know.
Old 01-12-2006, 10:44 PM
oldhalftons's Avatar
oldhalftons oldhalftons is offline
oldhalftons has a good reputation on FTE.oldhalftons has a good reputation on FTE.oldhalftons has a good reputation on FTE.
I know he's right
Old 01-12-2006, 11:58 PM
Polkat Polkat is offline
Polkat is starting off with a positive reputation.
Yes, but...a small amount of caster IS built into the beams. It can be adjusted with offset bushings when necessary, but it is there. Even the part numbers indicate a difference. If you switch them, your steering and stability may suffer.
Old 01-13-2006, 12:20 AM
Quote:
sorry but they are the same left and right. they measure the same, ford says they are the same, left and right have the same hollander #. There is no caster built in. there is some camber, but the kinpin centerline is perpendicular to the axle pixot centerline. There are no offset bushings, they have to be reamed in place.
Lots of trucks have beams with 2 different forging #s, the forging #'s indicate kingpin size and each size has several #'s.
You haven't had one of these front ends apart have you?
Old 01-13-2006, 11:48 AM
73FOMO's Avatar
Thanks guys. I just wanted to be sure before I got any further with the reassemble. I didn't think there was a difference, but I just wanted to be sure that caster wasn't an issue. My front end looks really good and tight now. New Kingpins, old one's were about frozen, and all new poly bushings. Pressure washed and sandblasted springs beams, front spring cups, and painted everything with a coat of chassis saver.
Old 01-13-2006, 12:40 PM
74 F100 351m's Avatar
74 F100 351m 74 F100 351m is offline
74 F100 351m is starting off with a positive reputation.
If your nuts that keep the kingpin in is in the frontyou are ok.
Old 01-13-2006, 03:40 PM
73FOMO's Avatar
What's that go to do with anything if the beams are the same? You can put that back in either way can you not?
Old 01-13-2006, 03:52 PM
If one is set to be on one side and you put on the otherside it could change the caster or camber, right or wrong.
Old 01-13-2006, 05:52 PM
73FOMO's Avatar
I think the bolt that holds the kingpin can go in either way as well, so I'm not sure if I could use that as a guide, but the census is that the beams are the same, so I think I'm going to leave it the way it is.
Old 01-13-2006, 11:12 PM
Okay, I'm confused, and you are right. The front suspension on these trucks are the only parts I've done little with. So how did the factory preset the caster? I read somewhere, and it made sense to me, that the caster was bent into the beam itself near the kingpin (the kingpin hole inclining slightly back) but you've assured me that this is not true!
Well, it doesn't appear that the radius arm pushes the bottom of the beam forward (or pulls the top back) as far as I can see (which would also tweak the shock, spring, and pivot bushing setup, which seems unlikely).
So can anyone explain to me how the factory initially set caster? Thanks.
Old 01-14-2006, 01:11 AM
caster is 0 degrees
front to rear, the kingpin is vertical. the beams have a camber angle built in, the top of the kingpin is a little bit outboard of the bottom.
Old 01-15-2006, 08:39 AM
73FOMO's Avatar
So that would be a slight positive camber? Positive is if the top leans out further than the bottom or is it just the opposite. I can't remember. Also, there is a machined flat area on the front part of the beam where the kingpin lockpin goes. Is this the side where the nut and washer for the kingpin lock goes? I think I put those in backwards. I have the locknut on the backside, not the side with the machined flat area. Would that matter? It doesn't seem to interfere with anything.
Thanks.
Old 01-15-2006, 09:27 AM
EricJ EricJ is offline
EricJ is gaining momentum as a positive member of FTE.EricJ is gaining momentum as a positive member of FTE.
Just from general knowledge, the camber would be built into the beam and it wouldn't matter which side it was on, it would be the same, and caster can be done by mounting the beams at an angle, it doesn't have to be set into the beam so even if it had a couple of degrees of caster it could still have identicle beams.
Headlight Problem and Random Connector Under Dash? DaMonsterMonster 1987 - 1996 F150 & Larger F-Series Trucks 6 11-29-2015 09:23 PM
Suspension Lift 4" or 6" 427mike 1987 - 1996 F150 & Larger F-Series Trucks 6 12-12-2014 07:05 PM
5 lug to 8 lug TIB (2wd) PlumCrazy* 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 06-26-2014 11:10 PM
How do you remove the long bolt holding radius arm to the I beam? 86fordtruck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 01-01-2012 05:29 PM
Bent I beams on 70swb elyons1970 1967 - 1972 F-100 & Larger F-Series Trucks 1 04-25-2011 02:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
