Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-12-2006, 12:14 AM
6t56 6t56 is offline
Garage is empty, add now
6t56 is starting off with a positive reputation.
factory disabled secondaries?
I recently bought a truck with a 477 in it.In the process of evaluating its problems I noticed that the vaccum secondaries were not opening.The carb is a holley and is the correct model for this engine,(I know this because it has linkage connected to it that is specific to this engine).The first thing that came to mind was a ripped diaphram in the secondary acuator.After taking it apart I found that the diaphram was not ripped,however there was a small ball like a B.B. blocking the vaccum port.This B.B. was obviously put there by the factory,but why?I removed the B.B.and got a lot more power out of the engine but it seems like it might be getting to much fuel because now it backfires when you let off the gas.(one really loud bang!!!!)What the heck is the deal?
  #2 (permalink)
Old 01-12-2006, 12:17 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
the BB was not factory just a PO's attempt to fix a problem. your best bet is to ditch that piece of crap carb they came with and get a new one.
  #3 (permalink)
Old 01-31-2006, 02:07 PM
Well then what are those bb's you get with a holley rebuild kit that you buy at the parts store?
  #4 (permalink)
Old 01-31-2006, 02:43 PM
those are for the power valve.
  #5 (permalink)
Old 01-31-2006, 11:35 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
I remember the old man talking about a "check ball" in the 4bbl on his 292 truck motor. This was a governed Holly, with vacuum secondaries. The idle was off the secondaries because of the governer.
If the check ball was missing, the secondaries opened quite easily, resulting in 4 mpg out of the F600 the 292 was in.
The carb is obsolete and you may not even be able to get a rebuild kit and drawing showing how/where etc the ball is supposed to be installed, and how the secondaries are supposed to be allowed to open.
If so, follow the previous advice and get a new carb.....
  #6 (permalink)
Old 02-04-2006, 11:26 AM
Marky Marky is offline
Marky is starting off with a positive reputation.
Carb Issues
If you want to save some money on a new carb, call around to some of your local carb rebuild shops. Most have unclaimed carbs they sell for half the price of a new carb. A friend told me this little secret and I found a carb for my old old truck for $65.00. A new carb would've cost over $300. Plus, I've found a rebuilt carb for my old Ford 2-N tractor for $40.00.
  #7 (permalink)
Old 02-10-2006, 08:38 PM
grclark351 grclark351 is offline
grclark351 is gaining momentum as a positive member of FTE.
the check ball is supposed to be in the vacuum diaphragm assembly, it has nothing to do with the power valve.
  #8 (permalink)
Old 02-10-2006, 09:45 PM
i just missed the edit, but anyways...
"The check ball is a way to meter the vacuum signal. If you look under the ball there is a groove for vacuum flow. It smoothes out the secondary opening. When the primary throttle shuts, the check ball opens and allows the secondaries to close instantly.
If you remove the ball, the secondaries can open more quickly. Maybe too quickly. Remember there is no squirter on the seconday side. Opening the secondaries too quickly can cause a stumble." -Clevelandstyle
Tags
disable, disablevacuumsecondaries, secondaries, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
