Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-11-2006, 04:16 PM
swords swords is offline
Garage is empty, add now
swords is starting off with a positive reputation.
Cool Bad surging after warm up
About a month ago my 89 ford ranger (with a 93 engine 2.3l) started surging but only when accelerating. sorta seemed like it was either out of gas or was fire correctly .. my father is a helicopter mechanic and has some experince with automotive and we both thought that it was a faulty fuel pump as ive been told that that year ranger had fault ones that tended to go out .. after replacig the pump assembly which was in the tank the problem continued. any how i replaced the sparkplugs and wires just as a normall tune up . the problem of course contiued. so i bought a code scanner and got code indicating the coolant temp sensor voltage was out of range, the egr valve position sensor indicating that it either was not opening correctly or not seated correctly and the o2 sensor was always reading the fuel to be lean and not switching ... i cant figure this problem out ive read alot of forums some saying that the cat might be the problem but recently the truck dies on me but always restarts.. some onehelp me .
  #2 (permalink)
Old 01-12-2006, 11:17 AM
mustangman mustangman is offline
mustangman is starting off with a positive reputation.
,,try replacing the tps sensor and idle air control solenoid,check for vaccum leaks extensively also replace baro/map sensor if equipped,go to the local bone yard,, very very cheap the way i get them
  #3 (permalink)
Old 01-12-2006, 12:10 PM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Hi swords, and welcome to FTE! Please take a moment to check out the guidelines, they contain important info you'll need when posting here:
http://www.ford-trucks.com/guidelines.html
I'd start with the EGR as indicated by your codes, take it off and clean it. Clear codes and run it, then pull the codes again if the problem persists. Also, some testing of the Coolent Temp Sensor and associated wiring may be in order. Once these problems are taken care of the lean O2 reading may very well sort itself out.
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #4 (permalink)
Old 01-13-2006, 08:02 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
I'd go with Tiger, and add that the EGR may be adding too much recirc, and causing misfire... thus leaving unburnt fuel in the mix. The O2 is confused, and thinks the exhaust is rich, because the O2 there has not been combined with the fuel. So, it will try to lean out the fuel mix.
Follow the codes in the sequence presented, as the FoMoCo guys know more than me, anyway. They can cascade and cause false readings if you don't. The CTS can lead the ECM to add extra fuel 'cuz it thinks the engine coolant is cold. The EGR can cause O2 to futz up as above...
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
Tags
1986, 1994, 2004, 23l, 40, 93, expedition, ford, gas, idle, line, misfires, ranger, surge, surging, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
