weird speedometer update
Thanks for the replies. I have changed the sensor on the rear end, the sensor on the tranny, tried another speedo with no change the speedo still bouncing and the o/d light is flashing. I also checked my speedo on another truck and is working perfectly. So i'm perplexe now. Where is the problem? From the PCM? The wiring? NEED MORE HELP . THANKS GUYS
E-150 1999 V-6 4.2L (analog speedo and odo)
O/D light flashing indicates there is a code in the processor. Retreive the code and see if that gives you a clue to the problem. Was the sensor in the rear end damaged physically? If so you may have some missing teeth on the reluctor that may give you a poor signal to the speedometer and pcm.
