runs with no battery
i was running my bII i noticed i knocked the cable off ( it loose cuase if i leave the cable on while it sits for a while it drains for some reason old battery i guess) and the engine didnt skip a beat the year is 1987 for some reason the battery light didnt light up ethier also all electical stuff works too i had no clue it would run with out a battery i knew older cars did but i figured the ecm and stuff would fail if the there was no battery imput this is pretty wierd could there be somthing wrong cuasing a short for somthing like this to happen or is the bronco II really that out dated that it just works with out a battery also shouldnt the battey light come on if the battery is missing?? lol i know the light it self works cuase its on if the key in on but the engine isnt any ideas??
If your alternator is working correctly, that appears to be functioning exactly as it should. The battery light will come on when the voltage drops below what it should be at, like when you turn the key on without the engine running, there is a draw to the battery, and no input voltage from the alternator. The alternator will provide the necessary current to run the efi, and also provide enough voltage that the battery light shouldn't come on, as it should be reading the voltage from the alternator, which is higher than the batteries anyways. I guess popping the cable off was just a good test that your alternator is in good shape.
Originally Posted by RomerB2
Would it run without the negative? I've always thought a car won't run without the negative, but it can run without the positive.
1989 Mudwieser
23
05-23-2015 10:33 PM
joshofalltrades
Electrical Systems/Wiring
16
11-05-2012 10:17 PM
firetree
05-10-2009 10:04 AM
yorxs
08-04-2003 10:41 PM
