Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-08-2006, 10:26 PM
chadjones99's Avatar
chadjones99 chadjones99 is offline
Garage is empty, add now
chadjones99 is starting off with a positive reputation.
Talking to wash or not to wash
that is the question ?
i just started making my own bio , and it looks good and clean, i know the washing is for getting out soap, extra menthol ,etc but if i have a newer ford, with viton (?) o rings,etc do you really need to wash the fuel, it adds on a lot of time in making it.
anyone out there who does not wash, please give feed back
thanks
chad
  #2 (permalink)
Old 01-10-2006, 01:44 PM
Fire Rooster's Avatar
Fire Rooster Fire Rooster is offline
Fire Rooster is gaining momentum as a positive member of FTE.
Chad,
I have been making BD for sometime now. I do wash mine; however you are correct it does add to the time frame etc. What I would also like to know is the amount of miles folks are putting on with unwashed BD. It does no good for someone to say "No I do not wash mine and its fine" Yet they only have about 3000 miles on it etc. I want to see higher mileage like 50-60,000 miles or more. So I will bump this to the top for you and watch it.
__________________
2012 F150 Screw, 2x4 XLT+, Bad Boy Black[SIGPIC]
2002 F250 CC,SB,4X4,Lariat...SOLD. 2003 X, limited SOLD
  #3 (permalink)
Old 01-10-2006, 02:55 PM
willbd willbd is offline
willbd is starting off with a positive reputation.
Chad,
Fabmandelux has the most experience making and running Biodiesel.
his quote below....
"I've been producing Biodiesel for almost 2 years now. I tried washing and didn't like it, to many problems. I make approx 800 gal/week, and let each batch settle 1 week in my first tank, then for 4 weeks in a second tank. I've had two samples CG tested and both have met ASTM spec biodiesel. So far I've had no fuel related problems.FABMANDELUX "
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
  #4 (permalink)
Old 01-10-2006, 07:44 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
Not knowing much about making bio....I would think that free methanol would be quite hard on HUEI injectors.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #5 (permalink)
Old 01-10-2006, 08:16 PM
Cookie,
Yes some will argue that it is not. However it really is, and this is why I wash. But like fab has stated he lets his sit for weeks. This will allow all the methanol to evaporate and or be recovered. If you bubble dry which is one of the techniques I use to dry the BD after washing, only use it to evaporate the methanol it should work well and speed up the evaporation time rather then weeks, could be a few hours.
__________________
  #6 (permalink)
Old 01-10-2006, 09:58 PM
rcdallas rcdallas is offline
rcdallas is starting off with a positive reputation.
Making 800 gallons a week? If producing that much definately out selling the stuff. That's alot of oil collecting....
__________________
99.5 F-250 4x4 400k miles! Ruenel Front/Rear Bumpers, Banks Exhaust Brake/Power Pack Hoss Level IV, Dual 5" Stacks, 12k Warn winch, Home Brewed WVO conversion.
  #7 (permalink)
Old 01-11-2006, 12:38 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
If you use the most recomended method, it call's for washing 3 times using 30 percent water each time. That means I would have 90 gal of waste water/100 gal of biodiesel! That's 750 gal/wk of waste water, a serious problem. As to miles using biodiesel; My 90 Dodge cummins has 42,000 miles on my biodiesel, my psd has 32,000 miles. The tractors,and irigation pumps have a total of 11,523 hrs on them. I have yet to experence my first fuel related problem. Before I started using bio in the Dodge I had the IP and injectors rebuilt, When it reaches 50,000mi I will send it back to the shop that did the rebuild and have it checked for wear. FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
