Turn signals
Old 09-24-2001, 06:37 PM
rwjr's Avatar
rwjr
rwjr is offline
Turn signals
Old 10-10-2001, 10:46 AM
79Supercab's Avatar
79Supercab
79Supercab is offline
Turn signals
I am having some problems with my right hand turn signal on my '78 F250 Ranger Supercab 4x4.
When the headlight switch is in the "Off" position everything works normal.
When the headlight switch is in the "on" position, the RH turn signal dash indicator light is always on and the it blinks very slow.
What would cause this?
Old 10-10-2001, 10:55 AM
sparky's Avatar
sparky
sparky is offline
Turn signals
Check/clean/ or replace as required the grounds for the RH turn signal/headlight. Should be on or near the rad mount. Couple of black wires. Also check the ground pin inside the turn signal bulb socket.
Most likely it is the socket assembly itself. Bad ground contact, so the running light is using a "floating" ground thru the signal light circuit. Which causes the dash indicator to glow.
Sparky
Old 10-10-2001, 11:00 AM
79Supercab's Avatar
79Supercab
Turn signals
Thanks.
'78 F250 Ranger Supercab 4x4, 400, 4spd, Dana 44/60 F&R, 4:10's, 33's, Dark Chocolate Brown, cherry condition.
Old 10-11-2001, 09:05 AM
benford's Avatar
benford
benford is offline
Turn signals
Hey, I am having the same problem with mine but it's the left turn signal, If it ever stops raining I'll go out and try to fix it, Thanks
Benford
Old 10-11-2001, 11:44 AM
tetraruby's Avatar
tetraruby
tetraruby is offline
Turn signals
Had same problem, as Sparky mentioned - check the ground. I ended up replacing the light socket. The ground contact was rusting away.
Old 10-11-2001, 08:51 PM
Supercab's Avatar
Supercab
Supercab is offline
Turn signals
Interesting to hear that others are having the same problem with the infamous Ford plastic light sockets that I've had for years, not just on trucks, but Ford cars as well, where do you get a good cheap replacement (new)?-my answer so far has been Pep Boy's for close to $20.00 each!!!!!!!!! otherwise its been the discount parts store (very cheaply made)for around $4.00 each.
Old 10-11-2001, 08:58 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,660 Likes on 1,342 Posts
Turn signals
You will find all brands of cars and trucks have the same problem.
Old 10-12-2001, 12:35 AM
BigBrownTruck's Avatar
BigBrownTruck
BigBrownTruck is offline
Turn signals
This has happened to me w/ both my 76 and my 79 multiple times, everytime replacing the bulb socket fixed the problem. The old ones just get old. I'm not replacing the replacements, just one by one replaceing the old ones.
BBT
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Turn signals
