1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Any luck adjusting Super-Cab doors?
Old 01-08-2006, 07:10 PM
m350's Avatar
m350
m350 is offline
A buddy of mine has a Super Duty SC, and the drivers main door looks like it needs to be adjusted in on the bottom,,,,anybody had any luck doing this ??
Old 01-08-2006, 07:15 PM
GaryT's Avatar
GaryT
GaryT is offline
Have the same problem on the passenger side door. It something I have not given much thought too. Would be interested to know if someone has taken on this challenge.
Old 01-08-2006, 07:55 PM
ixtlan's Avatar
ixtlan
ixtlan is offline
same problem,affects dome light switch
I have a 2001 250SD. If I close the drivers door by pushing it shut in the normal spot near the doorlatch it doesn't seem to shut as tight on the bottom, and the interior and rear cab lights stay on. If it is shut by pushing well below the latch, it is tight and the lights go off. I have seen a number of posts regarding these lights staying on, and I would guess that in many cases it is due to this. I would like to find out how to adjust the door. It seems like the only adjustment would be to try to slightly move the Nader pin, (but I'm not sure how much room there is to move, since it is held by two screws) or the upper door hinge.
Old 01-08-2006, 08:00 PM
sltrrco's Avatar
sltrrco
sltrrco is offline
I had mine adjust by a body shop for $40.OO and now it just real tight.
Old 01-08-2006, 08:22 PM
alchymist's Avatar
alchymist
alchymist is offline
"Mifflin Clay"
2005 - 6000 miles, passenger front door is not aligned in the opening - dealer is to fix it next time it's in for oil change. Not out much, just slightly noticable.
Old 01-08-2006, 08:29 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
these are just like any ohter car door just a few bolts on each hinge you can move it up down forward and back or tilt it in and out. there is a lot of movement once those bolts are loosened.
Old 01-08-2006, 08:54 PM
vancouverpower's Avatar
vancouverpower
vancouverpower is offline
The passenger door on my 99' super cab had a wind leak and rattled on washboard roads. I removed the (non adjustable) striker that's on the front of the rear small door and slotted the holes out in it. I moved it in about 1/4" and now it's perfect. If you do this you will need to but new (metric) bolts since the old ones have a tapered head. You will need a regular type bolt head and a washer. Don't forget the lock tight. I got this idea from somebody on this site bout I can't remeber who. Anyways it works great!
Old 01-09-2006, 03:27 AM
m350's Avatar
m350
m350 is offline
Thanks for the tips, the top looks tight,,just the bottom needs to go in 3/16 more or less.
Old 01-09-2006, 08:42 AM
yamahonda41's Avatar
yamahonda41
yamahonda41 is offline
I have the same issues on my '06 Crew cab. Driver door shuts easily but is noticably out a little at the bottom. Passenger door hardly ever shuts on the first attempt by someone who has not ridden in it before.
I have appt. on 1/11 at local dealer Body shop to adjust the front bumper that is almost 1/2" lower on passenger side. The service advisor told me on the phone that the Service dept, not the Body Shop, would adjust the door latches. Would be nice if Ford would do it right at the factory. PITA to have to take a $45k truck in for something so minor.
I am happy this is all I have had. 3400 miles and none of the other problems so far
No-Tyme
1983 - 2012 Ranger & B-Series
11-07-2010 06:00 PM
dunney1
05-02-2009 10:37 AM
dadlovesfords
1997 - 2003 F150
12-24-2008 05:55 PM
vinnyhoosier
2004 - 2008 F150
11-06-2007 12:55 PM
cmoore99
04-18-2005 04:21 PM
Quick Reply: Any luck adjusting Super-Cab doors?
