Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #106 (permalink)
Old 01-11-2007, 11:06 AM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by lionsteve
Since you own reading glasses I am guessing you are really old, like over 40.....lol
Steve
We wouldn't be picking on "us" senior citizens. At least we get a discount at most resturants. Jim
Ok I wear bifocals at least for now.
  #107 (permalink)
Old 01-11-2007, 05:40 PM
tarheel4ever tarheel4ever is offline
tarheel4ever is starting off with a positive reputation.
hey I have a step by step write up if anyone needs it! It's in word format! with pictures. It's only for the liftgate. I will work on the door when I get a chance!!! my email is srq4@hotmail.com if you can't get a response post here again and I will give my alt email.
  #108 (permalink)
Old 01-21-2007, 02:51 PM
Talltruck Talltruck is offline
Talltruck is starting off with a positive reputation.
I'm in the club, just finished both doors on my F250 & it's working as promised. Whoever came up with the solution to this problem deserves an award, I'm impressed. I had 2 cold beers after it was back together with all due respect....
  #109 (permalink)
Old 01-22-2007, 06:48 AM
Jzinkiewicz Jzinkiewicz is offline
Jzinkiewicz is starting off with a positive reputation.
I've tried this with no avail, question, where exacately are u spraying the wd.
  #110 (permalink)
Old 01-22-2007, 09:09 AM
vettdvr's Avatar
Where did the video post come from in Post 106? I didn't put it there. Jim An advertisement?
  #111 (permalink)
Old 01-22-2007, 11:03 AM
lionsteve lionsteve is offline
lionsteve is starting off with a positive reputation.
Quote:
WD? No WD needed to fix the locks?
Steve
  #112 (permalink)
Old 01-22-2007, 01:25 PM
how did u fix the locks?? everyone is saying to use wd40 but this didn't work for me. I don't know if i was spraying it in the right place to begin with
  #113 (permalink)
Old 01-22-2007, 03:16 PM
Post #3 of this thread will tell you all about it. There are even some pictures later on in the thread.
Steve
  #114 (permalink)
Old 01-24-2007, 06:37 PM
Cofooter Cofooter is offline
Cofooter is starting off with a positive reputation.
I've been following this thread for some time now and have been trying to find the time to get this done on my driver side door which went out last year some time. First the action got real lethargic, then it just quit all together. Same symptoms as you guys are having. Just as I was about to break down and do the work, the damn thing started working again, just like new, didn't touch a thing. The action is fast and as I said, works like the day I bought it. Now we've been have sub zero weather out here for several week and I'm wondering if the frigid tems have "healed" the thermistor in the circuit or at least masked the problem for now as it doesn't have a chance to get hot???? Just guessing here but am interested if anyone else is having this "problem".
Thanks.
  #115 (permalink)
Old 01-24-2007, 07:43 PM
sbc_prod sbc_prod is offline
sbc_prod is starting off with a positive reputation.
i just did this also and it works. the cold weather is making the locks work better. i did some tests on the thermistor and it has about 3 ohms at room temperature. when heated with a heatgun it got up to almost 3 mega ohms. i imagine when your interior is about 95 degrees in mid summer they don't work all that well. many thanks to the person who originally discovered this.
  #116 (permalink)
Old 01-25-2007, 10:47 AM
vettdvr's Avatar
Quote:
I found the same thing,, 3 ohms at room temps. This is why I solder an 18 gauge wire around the end of the metal plates to provide the new copper conductor. I have also cut a piece of copper to make an exact fit, won't say where the copper comes from, but it does cost me $.01 Jim
  #117 (permalink)
Old 01-27-2007, 11:03 AM
bigal6030 bigal6030 is offline
bigal6030 is new and has a neutral reputation at this point.
Someone please describe removing the lock assembly. I have the panel removed, I removed the 3 screws holding the lock assembly but how do you remove the assembly?
What is the best way to disconnect the connecting rod of the lock button and the interior lock handle?
Al
  #118 (permalink)
Old 01-27-2007, 12:55 PM
vettdvr's Avatar
I took screws on the interior handle out so it could be removed. Then separated the handle from the lock. Check the photos in the tech section they do help.
The green connector from the outside handle is removed with a long screwdriver.
The interior handle with pushrod has a swing away clip at the lock. If I remember correctly it has been a while, I removed the connector to remove the push rod. Jim
  #119 (permalink)
Old 02-03-2007, 12:51 PM
4running 4running is offline
4running is starting off with a positive reputation.
What is being wrspped with foil? is it the resistor itself? and this insulates it fromt he heat of the motor?
Am I correct?
  #120 (permalink)
Old 02-03-2007, 03:29 PM
Ok-
That "thing" is a little hard to spot, it looks like a small rectangular watch battery. Prying the motor apart is a little tricky too, but is does come apart. Upon re-assembly be sure that the small brushes are around the comm on the motor, and don't force it!
I used less than 1 square inch of foil to wrap both sides on my truck. WOW what a difference!
Tags
1995replace , 2000 , 2001 , actuatorf150 , door , f250 , f350 , ford , lock , locks , power , problem , resistor , thermal , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
