Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #91 (permalink)
Old 12-28-2006, 12:34 PM
mbryson mbryson is offline
mbryson is starting off with a positive reputation.
Just posting up to say I'll be doing this to all my locks on my '99 F250. I'll post the results later.
__________________
'99 (early) PSD, 4x4, crew, shortbed, auto
tows my YJ that's a little modded
  #92 (permalink)
Old 12-30-2006, 07:11 PM
LP2 LP2 is offline
LP2 is starting off with a positive reputation.
Thumbs up It really works!!!!!
It's hard to believe that such a simple fix cured the wife's excursion power door locks ,but it's true. I followed the steps in the thread .!st one took about an hour just because I was being overly careful I guess. Fixed the other 3 doors in about 30 minutes time each. I read that some folks used machine screws to put their actuator back together. I drilled all the way through and used wire ties on all 4 doors. GREAT THREAD!!!!!!
  #93 (permalink)
Old 01-03-2007, 07:08 AM
Jzinkiewicz Jzinkiewicz is offline
Jzinkiewicz is starting off with a positive reputation.
door actuators
I think i pretty much have a door actuators problem. How do I know for sure which door is the problem.
  #94 (permalink)
Old 01-03-2007, 07:47 AM
jade97's Avatar
jade97 jade97 is offline
jade97 is starting off with a positive reputation.
Quote:
It would be the door(s) that doesn't (don't) unlock, when you hit the switch/fob.
__________________
2002 F-250 Lariat CC SB 4x4 V10
2005 Ford Five Hundred SEL AWD
2005 Mercury Montego Premier AWD
  #95 (permalink)
Old 01-03-2007, 10:36 AM
neither doors work, but suspect it's the drivers side....I have to wait about 10seconds before the doors unlock using my remote. the alarm goes off every time..
  #96 (permalink)
Old 01-03-2007, 12:06 PM
jade97's Avatar
I would suspect either both actuators are bad, or the peoblem has something to do with the alarm/alarm installation.
__________________
  #97 (permalink)
Old 01-03-2007, 08:18 PM
Is there a way to isolate which actuator is faulty. I would hate to take apart the passenger side when it's the other
  #98 (permalink)
Old 01-03-2007, 10:01 PM
ssjrsw's Avatar
ssjrsw ssjrsw is offline
ssjrsw is starting off with a positive reputation.
As jade said most likely both are bad. If you are unsure of that start on the drivers side. I think you will find that after you do the repair the drivers side will work and the passenger side will not. If so then just do the same on the passenger side.
__________________
Scott
99 F250 Super Duty 4X4 XLT V10 5 SPD
98 Explorer 4X4 XLT 4.0 SOHC Auto
  #99 (permalink)
Old 01-04-2007, 08:07 AM
I thought as much , thanks for the tip. I'm going to try it and I'll let u know how it goes. If it's not the problem then at least I 've fix something before it breaks. I'm hoping it's not the alarm system. I think it's tied into it somehow.
  #100 (permalink)
Old 01-08-2007, 01:53 AM
tarheel4ever tarheel4ever is offline
tarheel4ever is starting off with a positive reputation.
I am glad I am not the only one with this problem!!!!!!
  #101 (permalink)
Old 01-08-2007, 07:01 PM
lionsteve lionsteve is offline
lionsteve is starting off with a positive reputation.
Did it today. Thanks for the info....
Steve
  #102 (permalink)
Old 01-10-2007, 09:20 PM
Dominiongen Dominiongen is offline
Dominiongen is starting off with a positive reputation.
Motor Tabs
i follwed the instructions in detail, and removed the assy. as stated, but the motor tabs are fully engaged into the openings they are bent over into. How in the heck did anyone get them pryed up? What kind of tool did you use.. I tried everything to get behind then and bend them up, but finally gave upp and put it all back together. Any advice would be most appreciated as im so close but yet so far if i can not get these dam tabs to bend up. I even tried looking up the numbers on the the web to just buy some new motors, but still no luck.. HELP Please!!
  #103 (permalink)
Old 01-10-2007, 09:25 PM
I hear you on that. It was a bear to get mine back also and as a matter of fact they got trashed while doing it. I used sharp tip awl. A really little screwdriver would work too. It was tough putting them back. I figured if I couldn't get them to push back enough to hold it closed then I would super glue the damn thing together...... Good luck.
Steve
  #104 (permalink)
Old 01-11-2007, 09:43 AM
Trouble1263's Avatar
Trouble1263 Trouble1263 is offline
Trouble1263 is starting off with a positive reputation.
I too used a small screwdriver and a sharp awl, just have to be patient not to break off tabs. It helped to use reading glasses to see the microscopic tabs. Good Luck.
__________________
Not much to see here folks,,move along!!
Duane
2001 F250 CC 172" 4x4 3.73 Lariat
6637, CCV, Isspro Gauges,Bilsteins,Mile Marker Hubs,Firestones,
4" Magnaflow SS,RDP-WW&HPX &GPR LED ,Foil Delete ,DP -NS/DT/S/80E/40T/Decel/60T/120R
  #105 (permalink)
Old 01-11-2007, 10:12 AM
Quote:
Since you own reading glasses I am guessing you are really old, like over 40.....lol
Steve
Tags
1995replace , 2000 , 2001 , actuatorf150 , door , f250 , f350 , ford , lock , locks , power , problem , resistor , thermal , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
