Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #421 (permalink)
Old 08-27-2009, 04:22 PM
kshultz kshultz is offline
kshultz is starting off with a positive reputation.
So, here's something else I noticed now that I've done both doors. The reassembly of the mechanisms inside the door isn't as difficult as their disassembly. In fact, there was really only one way to attach all the hooks and rods. Trying to do so differently doesn't seem like it would even work.
You can also operate the outer door handle, and the key mechanism, to help give you a clearer picture about what things attach to what. Between this, and moving the latch mechanism around with your fingers some while you've got it out, it's pretty obvious how stuff goes back together. At least, it was for me.
  #422 (permalink)
Old 08-27-2009, 04:28 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
Yea, if you are a little mech inclined you can do it. The main thing is to have a little mechanics mirror, long skinny screwdrivers, a little flashlight, and maybe a telescoping magnet and long needlenose pliers.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #423 (permalink)
Old 08-27-2009, 04:34 PM
snoxer's Avatar
snoxer snoxer is offline
snoxer is starting off with a positive reputation.
Unhappy sigh
well its been a year since i did mine with pennies.. their just starting to get weak again.. usually takes 2 tries to lock or unlock them now. not sure why they would though.. i don't think pennies can wear out lol
guess i'll have to take one apart and check it.
  #424 (permalink)
Old 08-27-2009, 04:54 PM
EXv10's Avatar
Strange, you can probably get some more at a wrecking yard.
__________________
  #425 (permalink)
Old 08-27-2009, 05:20 PM
Zaner21's Avatar
Zaner21 Zaner21 is offline
Zaner21 is starting off with a positive reputation.
Interesting. I wonder if it's the motor finally wearing out or if the copper has corroded over?
  #426 (permalink)
Old 08-27-2009, 06:41 PM
snoxer's Avatar
Quote:
suspecting the motors.. cause i put dielectric gel on the pennies.
unless i have a deeper electrical prob.. my battery has been getting weaker since winter to.. although i believe its 9 years old so i'm changing that tonight.
  #427 (permalink)
Old 08-27-2009, 07:34 PM
EXv10's Avatar
Very good idea.
__________________
  #428 (permalink)
Old 08-30-2009, 11:11 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE.
Since I finally did mine, I have to add my .02.
It's not necessary to remove the metal rivets. I was able to pry the halves apart the first time and drop the motor out. Because I wasn't paying attention, I didn't see the "thermal fuse" in the motor cap and ended up drilling them out anyway looking for it in the case. I was going from memory here....
Not sure how to handle the plastic posts this way but I'm going to try it when I have to do the driver door. Probably just drill them out from behind and use the same screws.
I snapped off all the plastic stubs and drilled through from the back where there were small holes already. Don't know the drill bit size, just grabbed one that was about the size of the hole. For the end where the case is narrow, I put the case back together and drilled from the front side using the holes in the front cover to help center it up. I used #8 x 1/2" wood screws to put it back together.This worked well. I didn't worry about the metal rivets because they were all the way on the end and I didn't have any screws handy that would work there. I figured now being assembled with screws it might be ok. We'll see.
__________________
Chris
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
"Maybe is for those who lack skill"
  #429 (permalink)
Old 08-30-2009, 11:50 PM
EXv10's Avatar
I used pieces of rebar tie wire on the first one and wrapped them through the holes and twisted the ends. With the rest I just opened up the end by the motor and left the other rivets intact. I didn't see the little square wafer either at first. In fact I almost gave up on the idea after not finding it in there (at first).
Sooo.... After removing the minimal amout of rivets by the motor , I just opened it up like a clamshell and dropped it out. The contacts go up and the part # goes down. No need to mark anything. I used some screws that were lying around that happened to fit in the 2 holes but I dipped them in a good glue first. All 5 have been great for the last year and they lock with a whack..........
__________________
  #430 (permalink)
Old 08-31-2009, 11:34 PM
Meeks's Avatar
Meeks Meeks is offline
Meeks is starting off with a positive reputation.
Can't believe i ran across this. Was about to buy actuators for three doors. Figures the only one it controls is my door. Gonna try it next weekend when I get back home. Really appreciate it.
  #431 (permalink)
Old 09-01-2009, 12:01 AM
snoxer's Avatar
well changed the battery.. for some reason the last owner had put a car battery in it.
new one has over twice the cranking amps. everything works great now.. except the door locks still too weak. so i guess they will have to come apart again. should be easier this time though.
  #432 (permalink)
Old 09-01-2009, 12:15 AM
firedewd's Avatar
firedewd firedewd is offline
firedewd is starting off with a positive reputation.
Fixed my two passenger side doors last week with help from this site. FTE Rocks!!! Now I noticed one door on my wifes chrysler minivan is failing the same way BUT only when that door has been sitting in the sun. Then I realized that the two doors I fixed on my F-250 were the ones that saw more sun as they face mainly south when parked. I am not sure if this is coincedence or not. Was wonder if anybody else noticed this on thier vehicles.
__________________
They told me it's not rocket surgery!
2000 F250 CC SB PS
Wilderness 5th Wheel
Starcraft Tent Trailer
The sooner I fall behind,
the more time I have to catch up!
  #433 (permalink)
Old 09-01-2009, 12:50 AM
EXv10's Avatar
Quote:
That makes sense because the thermisters (little square resister wafers) are very sensitive to heat. As soon as the electrical resistance builds up a little heat (from lying on the switch) they will quit transmitting juice. If you even use the switch a couple times in a row they will start to give up and the lock post just wiggles.
__________________
  #434 (permalink)
Old 09-01-2009, 01:01 AM
firedewd's Avatar
Quote:
My thoughts exactly. I warned my wife about holding the lock/unlock switch too long may burn out the repaired motors (I used the 1 cent method) but she won't remember until its too late. Also, I have been working in electronics/computers for over 30 years but have never seen a thermistor type device like this. Kept one to play with.
__________________
2000 F250 CC SB PS
  #435 (permalink)
Old 09-16-2009, 03:22 PM
fishpimp fishpimp is offline
fishpimp is starting off with a positive reputation.
worked like a charm...
Tags
1995replace , 2000 , 2001 , actuatorf150 , door , f250 , f350 , ford , lock , locks , power , problem , resistor , thermal , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
