Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #391 (permalink)
Old 06-07-2009, 10:16 AM
locknload223's Avatar
locknload223 locknload223 is offline
locknload223 is starting off with a positive reputation.
OK I tore back into it and found I was getting power to the actuator so I split the case open and found the problem. One of the male contacts that's attached to the case and slips into the motor was bent flat. So it looked like SpongeBob with a tooth knocked out. I must has really been in a hurry the first time around. I bent it back down reassembled and good as new. Thanks all. Great find. How many others are doing the remaining working locks as prevenative maintenance? Thinking it's a good project when bored.
__________________
2000 Excursion Limited PSD- DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80t, Drive-Thru, 80e, 120race, K&N Filtercharger, Exhaust, AIH delete, Foil delete, 4" lift, Airbags, 315/75/16's
  #392 (permalink)
Old 06-07-2009, 04:24 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
I wish I had done my others as P/M when I did the first one. I've only done them as they failed. I did my last one (of four) today, the first one was three or four years ago.
The problem with doing them "as needed only" is that I tended to forget the little details and tricks that made it easier, and it took a longer time each time. It was like each one was the first, time-wise.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #393 (permalink)
Old 06-07-2009, 04:37 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by locknload223 View Post
Howmany others are doing the remaining working locks as prevenative maintenance? Thinking it's a good project when bored.
Lot of people doing them . They don't have to take the door handle off or take that cable off though. They can just cram some tin foil in the slot in the motor also.
  #394 (permalink)
Old 06-07-2009, 10:07 PM
cokeman cokeman is offline
cokeman is starting off with a positive reputation.
I've been following this thread since it began. Thought for sure this is the fix I need for my driver's actuator. I never got around to doing the fix for several reasons and so I have been noticing something with this lock. Maybe someone can help decide if this is what I need.
My lock problems really only occur when it is rainy or very humid outside. Cold and wet sometimes causes it too. However, this is only when I use the remote on the door locks (aftermarket). When this happens, I test the lock with the switch on the door and it works, only just a little slow, but not too bad. So, I am thinking that the relay for the aftermarket remote is probably getting moisture in it and not really a bad actuator. However, this system has a relay for each side, so I would think that if the relay was the problem that the front and back on the driver's side would both stick. This is not the case.
Opinions?
__________________
Scott Coker
  #395 (permalink)
Old 06-07-2009, 10:35 PM
EXv10's Avatar
I doubt if the moisture is affecting the remote but it might the relay. I sounds like you need to do the fix on the drivers door. They open with a solid whack with the fix. Nice because you can hear it lock/unlock. The remote is just a switch, it either works or doesn't, but I can't help you with the relay the remote operates. The more I read this the less I realize I know about it but I would start with a fix on the drivers door as they all go bad eventually and it might cure the problem.
  #396 (permalink)
Old 06-08-2009, 10:10 AM
I should clarify my post. The remote is fine. It's the relay for the system that I am wondering about. But, as you say, the lock should have a solid "whack" when opening. Just seems strange that when it hangs, it hangs when unlocking from the remote, but works with the door switch. My theory there is that the actuator is actually going bad like all the others and what I am seeing is that the relay is not letting as much power through as the door switch does (it's parallel to the stock circuit, not in line) and so that drop in power accents the bad actuator. That would also explain why the other lock on that circuit works fine.
__________________
Scott Coker
  #397 (permalink)
Old 06-08-2009, 10:49 AM
EXv10's Avatar
That makes since but I would still start by fixing the old slow actuator.
  #398 (permalink)
Old 07-19-2009, 08:48 PM
gitane59 gitane59 is offline
gitane59 is starting off with a positive reputation.
thanks and reps pionts to the OP for this super fix. i did all four of my doors yesterday with total success. Thanks again.
__________________
2001 F350 Lariat CC 2WD SRW SB V10 Two-Tone Green & Gold
2001 Newmar 34BLDS Kountry Star
  #399 (permalink)
Old 07-19-2009, 08:58 PM
jeffdoerr jeffdoerr is offline
jeffdoerr is starting off with a positive reputation.
subscribed
__________________
00 F-350 Lariat 7.3 CC LB 4x4 3.73 l/s, 275k, pop-up GN hitch, 6637, foil delete, BD X-monitor, DP Tuner decel/40/80/140/drive-thru
99 F250 Lariat v10, ext cab, bone stock 285k miles, boss v-plow
99 F250 XLT 7.3 6spd 4x4 6637, DP tuner 40/80/120, 5 in exhaust 345k miles
  #400 (permalink)
Old 07-20-2009, 12:16 AM
EXv10's Avatar
Did all 5 of mine and saved hundreds I don't have.
  #401 (permalink)
Old 07-23-2009, 06:03 PM
RckyMntnKng's Avatar
RckyMntnKng RckyMntnKng is offline
RckyMntnKng is starting off with a positive reputation.
I did all 4 of mine a while back. Decided to do a little test and did the front passenger door with a brand new ford actuator and the 3 remaining with the tin foil.
Guess which one went out a couple months back already after less than a year....
__________________
2001 F350 4X4 Lariat Crew Long 7.3L w/FMRs - 4" Magnaflow, CAI using 6637 and Petes Cover, 3-ISS pros, TS 6 pos chip, 4" Rancho Springs, 315 Toyo Mts, Bilstein 5100's, Rock Tamer Flaps, 2din MP3, Pioneer 4ways in all doors, Infinity 10's @ 1200w,......205k and still going strong with Tin foil locks, new clockspring, and Brand new hub assemblys!
  #402 (permalink)
Old 07-27-2009, 12:08 AM
volez volez is offline
volez is starting off with a positive reputation.
Followed kalsc's directions and posted a photo step by step in the album section. My friend was too nervous to do it without seeing it.
http://www.ford-trucks.com/forums/al...p?albumid=3215
  #403 (permalink)
Old 07-27-2009, 12:20 AM
2000 Ford F-350
Volez,
If you use an exact knife to cut the heads off the plastic rivets first, you don't have to pry so hard to get the cover off, and you don't have to file later.
It looks like you brute-forced the motor's end-cover off, too, and then straightened the little tabs. A pair of needle-nosed pliers will bend the tabs first to allow the brush end of the motor to be removed without damage.
To re-install without the possibility of damaging the brushes, a piece of paper clip can be trimmed and inserted in the end cover to hold the brushes open while installing over the armature.
You should replace the rivets with #4 or #6 screws. There's more internal pressure at that point, that's why they were metal rivets.
Pop
__________________
Email SpringerPop
  #404 (permalink)
Old 07-27-2009, 01:15 AM
EXv10's Avatar
An easy way to bend up those 2 tabs on the motor bell is to drill a shallow hole behind each one first. Also, instead of putting tin foil around the resistors you can throw the culprits away and just cram tin foil in the contacts where it was. Also you don't have to separate the halves. You can just drill the rivets out by the motor, spread the halves and drop it out. Also there is no need to mark the bell and motor because the part # goes down and the contacts go up. The paper clip brush holder is a good idea, I used another method the first time All 5 of mine are still working like a champ.
  #405 (permalink)
Old 07-27-2009, 08:42 AM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by SpringerPop View Post
Volez,
If you use an exact knife to cut the heads off the plastic rivets first, .........Pop
I just use a drill press and drill out the plastic head. I use a large enough bit to drill the entire head. Of course I only drill until it cuts the head off. Then I drill with a 1/16 bit and use a socket head wood screw to put it back together.
I use a dental tool to open the motor tabs but I never fully straighten them only enough to get the back plate off.
Tags
1995replace , 2000 , 2001 , actuatorf150 , door , f250 , f350 , ford , lock , locks , power , problem , resistor , thermal , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
