Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #361 (permalink)
Old 02-10-2009, 03:58 PM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by NAMDROF View Post
All assembled and thought I woulod bench test the actuator and it throws it twice as far when locking then it does when unlocking? Is that normal?
you are just probably hitting the stops. Test install one and try it out.
  #362 (permalink)
Old 02-10-2009, 07:12 PM
NAMDROF NAMDROF is offline
NAMDROF is starting off with a positive reputation.
Must be
Works like a champ!
Thanks for all those who posted in this big O Thread!
  #363 (permalink)
Old 02-10-2009, 08:15 PM
vettdvr's Avatar
Works like a champ!
You're most welcome. I came up with the $.01 repair then changed to the solder repair.
  #364 (permalink)
Old 02-11-2009, 04:05 PM
Bob1951 Bob1951 is offline
Bob1951 is starting off with a positive reputation.
Hi, My son has just bought a one owner 1999 F - 150 XLT with supercab. We love it. I thought I would fix the power door lock actuators and have used the mod found on this site. My problem is the window track now. I removed the lower bolt that holds the window track in place and when I buttoned everything up the window would get stuck as it goes down. Looking up towards the top of this track, bar I see it goes into a square metal holder housing. On the bar or track is a small bent curved metal clip. Does this clip go behind the holder housing on set inside it? Any help would be helpful. Thank you. Bob1951
  #365 (permalink)
Old 04-04-2009, 11:09 AM
ol'yeller ol'yeller is offline
ol'yeller is starting off with a positive reputation.
Did mine yesterday. I used sheet metal screws to hold motor halves together. The first one took 1 1/2 hours. The second took 30 minutes. Great info! I'm glad to get mine working again.
Greg
__________________
I am not a mechanic, although I do play one in my garage.
  #366 (permalink)
Old 04-04-2009, 08:34 PM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 is starting off with a positive reputation.
Just finished my son's crew cab, plus last year I did my supercab, that brings the savings up to a few hundred bucks, and I can kick them out pretty quick now.
__________________
2001 F350 V10 2WD
2001 F350 V10 4WD
1999 E250 5.4 High Top
1989 Thunderbird SC
65 post 442
65 vert 442
  #367 (permalink)
Old 04-14-2009, 01:44 PM
JOHNNYRICH10's Avatar
JOHNNYRICH10 JOHNNYRICH10 is offline
JOHNNYRICH10 is starting off with a positive reputation.
Well i got my back passenger door done and put back together.......................appearently when i was testing to make sure they worked i did not notice when i hit unlock it locks and vise versa, with my keyless entry. this is my first door, anyone know if i have to take the whole door back apart or if there is an easy fix
  #368 (permalink)
Old 04-14-2009, 01:55 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
You didn't read this whole thread before you attempted this repair, did you?
The short-cut screwed you. Yes, you have to take it all apart again. You put the motor together wrong.
Of course, you COULD take another short-cut and reverse the two wires on the actuator.
Two wrongs make it act right. But it's still wrong.
See post 226 in this thread.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #369 (permalink)
Old 04-14-2009, 02:14 PM
thanks, and no i did not
  #370 (permalink)
Old 04-14-2009, 03:00 PM
priusron priusron is offline
priusron is starting off with a positive reputation.
Hey Pop, do you think you could help someone without being so rude. That thread is so long it is hard to read. The job is hard to do, it took me 1 1/2 hrs to get my first one out, most of that time was spent reading and trying to figgure out how to do it. If you are going to spend time replying, how about really replying instead of just saying "see post 226" which is what you just said. It would have been more helpful to actually refer him to the post that describes reassembly of the motor.
This forum is supposed to be to help someone, not to tell them how stupid they are becaus they did not read over 300 posts.
Ron
  #371 (permalink)
Old 04-14-2009, 04:55 PM
mauger's Avatar
mauger mauger is offline
mauger is starting off with a positive reputation.
THANKS, worked like a charm. The only thing I did different was used a piece of sheet steel cut to the right size instead of tinfoil.
  #372 (permalink)
Old 04-14-2009, 05:13 PM
2000 Ford F-350
Ron
The Lord helps them that helps themselves.
I guess the intent was to remind you to READ. After all, this is a text-based forum, and it is all there.
We spoon-feed it to you guys. What more do you want?
You demand the Cliff's Notes! Sheeesh! The easy way out.
Nothing more from me in this thread...........
(unsubscribed)
Pop
__________________
Email SpringerPop
  #373 (permalink)
Old 04-14-2009, 07:42 PM
mauger's Avatar
Ron
Sorry to but in here, I don't think you are stupid but you didn't have to read 300 posts. The super-long paragraph had all the info in it, and as far as putting the back of the motor on wrong, The first rule of taking stuff apart is to mark everything so it is put back together properly.
IMO the hardest part of the job is the r&r of the lock mech.
  #374 (permalink)
Old 04-14-2009, 08:30 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
I wonder, if this thread needs to be split up?
Anyone want to go through, tell me what posts are REALLY important and I'll pull everything else out of it?
Sheesh, 25 pages of posts to go through
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #375 (permalink)
Old 04-14-2009, 11:52 PM
Hey guys, I took it apart again put the motor in RIGHT this time. And i just finished the second door. As far as Pop being rude, I am a grown up I can take it . i figured if i looked hard enough i could find the answer but I think i got it faster by posting the question then i would have going through 24 pages of posts.and seeing as i am trying to do these locks through my lunches and after work before it gets dark rude or not it actually helped I appreciate all the help. This is an awesome fix and it will save me alot of leaning over and unlocking the door for people.
Tags
1995replace , 2000 , 2001 , actuatorf150 , door , f250 , f350 , ford , lock , locks , power , problem , resistor , thermal , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
