Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #346 (permalink)
Old 10-26-2008, 03:09 PM
BIG BOI's Avatar
BIG BOI BIG BOI is offline
BIG BOI is starting off with a positive reputation.
Update, Had a brainfart earlier, the part i pulled out was the window motor, put it back in and grabbed the right part, followed the instructions to the "T" that aluminum foil trick did the job, the driver side front and rear door now works, decided to do the hatch as well, and what you know, it works. this little fix saved me over $100.00
thanks all for the info and the directions.
  #347 (permalink)
Old 10-26-2008, 05:27 PM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
1999 Ford F-250
zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of
Good deal, it always helps to work on the broken part when trying to make repairs.
  #348 (permalink)
Old 10-26-2008, 05:47 PM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
The hatch has the same setup. You can remove the motor from the hatch without removing the latching mechanism. I just unplugged and then removed the motor. There was just enough room to pull the motor out and leave the latch in.
  #349 (permalink)
Old 10-26-2008, 06:23 PM
BIG BOI's Avatar
Yup, the hatch was the easiest to remove, and yes it's always a good idea to actually work on the part that is broken :-)
  #350 (permalink)
Old 10-27-2008, 04:14 AM
dubble-dee dubble-dee is offline
dubble-dee is starting off with a positive reputation.
Has anyone had their fixed locks work, and then start acting up like before? I fixed mine during the winter with the 2 cent fix, now they're just like they were before. I guess i'll have to break down and get new ones.
  #351 (permalink)
Old 11-08-2008, 03:11 PM
poko2002 poko2002 is offline
poko2002 is starting off with a positive reputation.
My thanks to the originator of this procedure. Without it I would have had to buy new actuators. It is easy and works.
I did this fix over a year ago on the driver side and it is working flawlessly. I now just did the passenger side of my 2000 f150. I think the fix is much better than buying a new one which could also fail.
The only thing I did differently was to epoxy the posts instead of replacing them with screws. After installing the repaired motor and snapping the two halves together I applied a small amount of epoxy to the shaft ends. Test it first because it will not be easy to disassemble it again. I believe this will be the final fix - better than new, and will outlive the truck.
See the post for "Actuator removal and replacement" to get the actuators in and out. I used this one:
http://www.ford-trucks.com/forums/22...olsusercptools
No rods or rivets to remove. Just snaps out on my 2000 f150. Don't remove the wire connector until the actuator is out. Then reconnect it before reinstalling.I think its easier and if you drop it in the door it is easier to retrieve it.
  #352 (permalink)
Old 11-08-2008, 03:53 PM
If anyone gets this far in this long thread I would like to say that (on my 2000 f150 xlt anyway) you DO NOT have to remove the entire lock assembly to remove the actuator. See the link in my prior post.
I removed one bolt which holds the window track for easier access. Snapped the actuator off the lock and removed the wire connector. No handles, locks, rods, or rivets etc to remove.
  #353 (permalink)
Old 01-02-2009, 05:35 PM
jhm3rd jhm3rd is offline
jhm3rd is starting off with a positive reputation.
Have a 2002 F250 SD. Back doors were nover locking or unlocking ..... Did the fix to them and it works great.
Was going to do the fronts, but the torx head bolts are installed with loc-tite and two of them stripped out in the torx area .... of course one on each door. I'll have to drill them puppies out if I ever get the urge to fix these .... but they work for now so .... Hey!
Thanks for the ideas on this thread ..... works great.
I only pried up enough to remove the motor and then zip tied back around where the motor is. The worst part of the whole job is undoing them little clips for the rods ... everything else is gravy
  #354 (permalink)
Old 01-03-2009, 07:42 PM
GR$$N$'s Avatar
GR$$N$ GR$$N$ is offline
GR$$N$ is starting off with a positive reputation.
im having a little trouble understanding this completely. does anyone have a detailed step by step instruction on how to do this.maybe some pictures too.thanks guys.if its easier to email me then my email is drgxxx@sbcglobal.net
__________________
nitrous is like a gorgeous blonde with stds, you wanna hit it but your scared of the consequences
  #355 (permalink)
Old 02-09-2009, 07:41 PM
mustangmad mustangmad is offline
mustangmad is starting off with a positive reputation.
Never mind, my questions have been answered. Thanks for the great fix!!
  #356 (permalink)
Old 02-10-2009, 02:07 PM
NAMDROF NAMDROF is offline
NAMDROF is starting off with a positive reputation.
Motor Tabs
Doing my locks today. I got the assembly out of the door. I get it opened up. Take out the motor. BUT! What do you use to bend the tabs back that hold the motor together? They are tough little buggers! Must be an easier way to do this? I have tried prying them back but they are so pinched down onto the plastic I cant seem to get them up?
Any tips?
  #357 (permalink)
Old 02-10-2009, 02:22 PM
vettdvr's Avatar
Quote:
Any tips?
I used a very small blade screwdriver. WARNING don't try to bend them straight, just enough to get the back cover off. Hope you marked which way the motor came out. AND BE sure to put the back cover on exactly the same way it came off. Failure to do so may give you reversed door locks.
  #358 (permalink)
Old 02-10-2009, 02:38 PM
Thanks vttdvr
My problem is it appears they bent the tabs more than 90 degress right down into the plastic. Thought before I go crazy on them come and see what other's do or did. I have marked everything and read thru all the posts before but trying to go find this info back in the posts I didnt see anything but it could be I was scanning looking so I may have missed it?
Thankks for the quick post!
OK Back to the Vise!
  #359 (permalink)
Old 02-10-2009, 02:47 PM
Got it
The one was so far pinched in tho it broke off try to pry it up? The other one was fine. OH well!
  #360 (permalink)
Old 02-10-2009, 03:45 PM
I/2 the throw?
All assembled and thought I woulod bench test the actuator and it throws it twice as far when locking then it does when unlocking? Is that normal?
Tags
1995replace , 2000 , 2001 , actuatorf150 , door , f250 , f350 , ford , lock , locks , power , problem , resistor , thermal , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
