Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #316 (permalink)
Old 07-01-2008, 02:36 AM
snoxer's Avatar
snoxer snoxer is offline
snoxer is starting off with a positive reputation.
been about 2 months since i used this fix.. still working like new . Thanx!
  #317 (permalink)
Old 07-05-2008, 12:17 AM
powerstroke_n powerstroke_n is offline
powerstroke_n is starting off with a positive reputation.
I went the penny route about 6 months ago and still works like day one. Just use a pair of tin snips to cut penny down to size. Works like a charm.
  #318 (permalink)
Old 07-28-2008, 12:25 AM
snowhounddogsledding snowhounddogsledding is offline
snowhounddogsledding is starting off with a positive reputation.
Fixed Locks!!!!
Hey all have been lurking for a while searching for my truck I just got my PSD 99 CB LB and have found all kinds of little bugs that have been solved from this site.
My biggest items so far were the overhead computer (500 from dealer ) and the door locks (50 X 4 from dealer ) and god forbid if I would have had the dealer do the work. My cost Free.
Thanks everyone on the locks, all the input really made this go smooth. I went the cooper wire route and drilled the plastic studs and used some small finish screws I had. I would like to find a source for replacement motors closer to spec. if I run across any I will post the source.
Thanks again
Seth
  #319 (permalink)
Old 07-31-2008, 08:57 AM
JOHNNYRICH10's Avatar
JOHNNYRICH10 JOHNNYRICH10 is offline
JOHNNYRICH10 is starting off with a positive reputation.
Ok, my locks are not working right know. I push the unlock button and all the locks twitch but do not unlock. With the fix above fix that?
01 F250
  #320 (permalink)
Old 07-31-2008, 08:59 AM
Jzinkiewicz Jzinkiewicz is offline
Jzinkiewicz is starting off with a positive reputation.
I'm telling you, it's the imfamous GEM module. other fixes are temp.
__________________
02' F350 XLT 7.3L,SC,SB,SRW. 75k miles. 6637 intake, DP Tuner, Overboost annihilator, 4" Exhaust.
  #321 (permalink)
Old 07-31-2008, 09:01 AM
ok thanks, just trying to find a cheap way out. I can live with it for now
  #322 (permalink)
Old 07-31-2008, 11:47 AM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
Quote:
Originally Posted by JOHNNYRICH10 View Post
Ok, my locks are not working right know. I push the unlock button and all the locks twitch but do not unlock. With the fix above fix that? 01 F250
The clue is that yours "twitch".
Yes, the above fix should work for you, but I'd be reading the entire thread (yes, ALL of it) before beginning, as there's some good tips along the way that will insure a good outcome, including not having them go the wrong direction after you finish.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #323 (permalink)
Old 09-15-2008, 09:36 AM
68, 60 Effie 68, 60 Effie is offline
68, 60 Effie is starting off with a positive reputation.
This fix worked great. It cost me $0.04 to fix four doors. It took me a little time, but it was worth it. Thanks.
  #324 (permalink)
Old 09-15-2008, 09:49 AM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Quote:
Glad the .01 fix worked. If you know how to solder I found another way to save $.01. Just use 18 ga copper wire about 1/4" long and solder around the end of the thermistor.
WARNING HOLDING THE BUTTON DOWN WITH THIS JUMPERED COULD BURN OUT THE MOTOR and all the rest of the disclaimers.
Remember to consult with your dr. before changing medications.
  #325 (permalink)
Old 09-16-2008, 08:14 AM
MarkMoore's Avatar
MarkMoore MarkMoore is offline
MarkMoore has a good reputation on FTE. MarkMoore has a good reputation on FTE. MarkMoore has a good reputation on FTE.
I completed this sometime back but had a recent issue arise with my fix. So here's a word for the wise... make sure when you reassemble the housing, you secure it very well. I had used some cheap 'all situation glue' because it was all I had at the time - the driver's door lock came 'unglued' and the gears jumped off track - you may surprised how much torque these little motors produce.
Of course this was a pretty easy fix, I just had to take the door back apart to do it. I added 2 zip ties around the housing. While I was at it, I zip tied the remaining ones as well.
I had one motor that I had previously fixed, fail completely - when I disassembled it I found that one of the little brushes at the tip of the motor (inside) had broken off. When you open the motor, you'll see 2 little copper springs that hold 2 little metal brushes - It appears that when I put it back together I didn't get the shaft in the middle and one of the springs was bent and the brush had snapped off. These things are tiny and I couldn't get back on - the motor is totally DOA now. So pay special attention to this when reassembling the motor. I wonder if I can find a replacement motor?
So out off four, I only need to buy one... better than having to buy 4!
Now I just need to get the rear hatch actuator fixed. It unlocks, but doesn't lock. I took the trim off and looked at how it was in there; it looked like too much of a task for me to complete at this time (some of the nuts will be a PIA to get to without some good swivles and extensions). So I treid just lubing everything with some Lithium to see if that freed it up - no luck. So for now, I just unplugged it.
__________________
- The Urban Assault Vehicle -
2001 Excursion Limited, 4x4, V10, 3.73
RoadMaster Active Suspension
2001 Prowler 31G
Equal-i-zer WD Hitch
Prodigy Brake Controller
http://www.ford-trucks.com/user_gall...id=194723&.jpg
  #326 (permalink)
Old 09-16-2008, 08:51 AM
vettdvr's Avatar
JUST INFO on reattaching the cover plate after repairing. I drilled out the plastic rivet heads until they were just cut through enough to remove the head. Then On reassembly I drilled a 1/16" hole in each rivit. I used a round head screw and washer allowing the screw to cut new threads into the plastic post that remains after drilling the head off. With screws in there is no tie wraps to get brittle and crack and no glue to come apart. The screws will be permenant.
  #327 (permalink)
Old 10-04-2008, 04:54 PM
jermort's Avatar
jermort jermort is offline
jermort is starting off with a positive reputation.
Finally broke down and did mine. A lot easier when you remove both the inner and outer door handles!!!!!!
Drilled off the top of the f&^%*&g plastic posts, then put a small pilot hole in each.
I took the thermistor, cleaned it, sanded down one edge and soldered a wire along the edge so that both sides were connected!!! FIXED!!!!! Screwed the thing back together, reinstalled.
Damn, the locks sure work nice now.
Good fix!
jammer
__________________
PSD #3 '95 loved it... '97 real POS...
2000 SC SB PSD E4OD 3.73 DS Predator (smokin') K&N Filter ISSPRO Gauges F**D Fog Lights Mickey Thompson 305/70 Baja ATZ 4" Dynomax Exhaust Sylvania SilverStar Lamps ARE Lid Very BLACK... Perfect!!
  #328 (permalink)
Old 10-04-2008, 05:07 PM
vettdvr's Avatar
Good fix!
jammer
That is exactly the way I make the repair. Works
  #329 (permalink)
Old 10-04-2008, 06:29 PM
jermort's Avatar
If I had it to do over, I'd just drill a hole through the thermistor, insert wire, solder, sand flush and go. But, along the edge worked fine; just takes a little longer. I clamped the thermistor is a pair of hemostats and soldered the wire along the top edge. Being anal as I am, I then sanded the whole affair flat, rounded the corners, looks factory . Hey, saved $100 just in parts!!
happy camper!!
jammer
__________________
  #330 (permalink)
Old 10-04-2008, 08:50 PM
2000 Ford F-350
Quote:
Exactly how I did mine, too!
Keeps the job neat, and it's now servicable.
Pop
__________________
Email SpringerPop
Tags
1995replace , 2000 , 2001 , actuatorf150 , door , f250 , f350 , ford , lock , locks , power , problem , resistor , thermal , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
