Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #301 (permalink)
Old 05-28-2008, 01:17 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
What vibetech said ^ ^ ^ ^ ^ above.
It a bit to wade through, but it contains all the information you need to git-'er-done!
If I were you, I'd read it all, as there are some subtle tips contained therein.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #302 (permalink)
Old 06-01-2008, 10:58 PM
neighborman neighborman is offline
neighborman is starting off with a positive reputation.
This has been a problem on my F350 for a couple years now. I finally decided to do some research, and I'll be doing the "fix" tomorrow. Thanks!!!
  #303 (permalink)
Old 06-10-2008, 03:05 PM
Update: Did the aluminium foil thing and it worked like a champ! Thanks!!
  #304 (permalink)
Old 06-17-2008, 07:33 PM
texasft texasft is offline
texasft is starting off with a positive reputation.
what are yall using to get the penny down to the correct size? I used a bench grinder and file for the first two doors, but this takes about 40 minutes. Any suggestions would be appreciated.
  #305 (permalink)
Old 06-17-2008, 08:18 PM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Quote:
Well now I never said I used a penny for the $.01 fix. However one could be used if it weren't illegal. The copper would make a excellent conductor. But if it were legal and I used a penny I would use my bandsaw to cut it. If I didn't have the band saw I would hold the penny in a vice and use a hand hack saw. However if you were to insert one in the motor in series with the brush so your lock motor would work there would be the possibility that someone might inspect the inside of the door panel, open the lock motor and then disassemble the motor to find the penny. Then you would be in big TROUBLE for defacing US money
  #306 (permalink)
Old 06-17-2008, 08:22 PM
so people aren't using .01 cent? If not, then what besides the foil?
  #307 (permalink)
Old 06-17-2008, 08:25 PM
vettdvr's Avatar
Well,, ,,, $.01 worth of copper,, now where could you find it.
  #308 (permalink)
Old 06-17-2008, 08:30 PM
ok I think I get it. You are using change, but just being sarcastic^^^^^
  #309 (permalink)
Old 06-17-2008, 11:31 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Quote:
In about 1/3rd of a penny? (or some other figure, copper went WAY UP)
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #310 (permalink)
Old 06-18-2008, 12:25 AM
reddogracing's Avatar
reddogracing reddogracing is offline
reddogracing is starting off with a positive reputation.
easier yet then a penny, A piece of house wiring, romex. A scrap piece you might have around, or stop in at the next contruction site you see and ask, you only need a piece shorter then a foot. It has solid copper wire that is about the right thikness, just keep doubling it back on itself, and you can make a piece the same size as the piece you removed.
__________________
01 F350 V10 auto CC 4x4
http://www.reddogracing.com/0a47c540.gif
  #311 (permalink)
Old 06-18-2008, 07:22 AM
vettdvr's Avatar
Quote:
You figured out the solution.
  #312 (permalink)
Old 06-19-2008, 10:56 PM
Got it. All the doors are done and lock/unlock great. Thank yall for this awesome site, and the great knowledge. Also, the hacksaw works way faster than a bench grinder, oddly enough.
  #313 (permalink)
Old 06-20-2008, 08:31 AM
gatorshooter's Avatar
gatorshooter gatorshooter is offline
gatorshooter is starting off with a positive reputation.
If and only If I did the fix and If I would of used the .o1. Id cut it with just a pair of side cutter pliers then I'd just bend it back an forth untill it broke in 2. then I would of used a flat mill file to bring it down to exact size and shine up the contact areas. the side cutters will work fine ....IF I did this.
My doors work fine ......Now!
GS
BTW Thanks to all who contributed to this tread it saved me some real $$$$$$s...... almost 2 full tanks of diesel!
  #314 (permalink)
Old 06-20-2008, 08:40 AM
vettdvr's Avatar
GS
Yup! If you had a $.01 and decided to do it that way it would work!
  #315 (permalink)
Old 06-22-2008, 11:58 PM
specializedcc specializedcc is offline
specializedcc is starting off with a positive reputation.
Ive done 3 out of 4 doors now! Man thanks to whoever posted this. You have saved a lot of people a lot of money! But watch out Im sure ford has a price on your head from all the actuators they should be selling!LOL, Thanks again whoever you are.
Tags
1995replace , 2000 , 2001 , actuatorf150 , door , f250 , f350 , ford , lock , locks , power , problem , resistor , thermal , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
